Can anyone help??? I have tried everything I can think of and my processor still overheats. It idles at 50C (I have checked in Bios and in the PC probe utility supplied with the board) and when I try and play ghost recon or any other game the temperature shoots up top the high 60C's and it locks up. I have tried 2 different heat sinks and have tried re-applying thermal grease (after cleaning it) a bunch of times. I have also tried three different types of thermal grease. (arctic silver, grease that came with upgraded heatsink and grease that came with stock). This is the third Striker Extreme board that I have recieved and I really dont want the aggravation of another RMA. (first one was completely dead out of the box, second one had same CPU temp problems).Also, if it relevant, when I instll the AI booster that came with the board, when I boot up, it will run until everything is all loaded then shuts down and restarts. the only way I can stop this is by booting into safe mode and unistalling it. I have nor overclocked anything. Everything is stock.
my setup is -
Striker Extreme Motherboard Bios Version 1503
E8400 processor
2GB Crucial Ballistix
8600GTS graphics card
850 Watt PSU
2 IDE 500GB hard drives
1 Sata DVD Drive
Antec 900 case (with optional fans installed and running)
All case fans are set on high
Running Windows XP profesional
Thanks!
my setup is -
E8400 processor
850 Watt PSU
1 Sata DVD Drive
Thanks!
