Endersun :
I do have my eye on that line of ASUS boards... I'm thinking
ASUS P5N-E SLI LGA 775 NVIDIA nForce 650i SLI ATX Intel
it seems like the plus your paying a lot extra for the PCIEx1 sound card, not sure though, theres so many boards that fit my requirements.
all I basically need is:
DDR2800 standard
SLI compatable
takes 1333 FSB C2D
I also want it at an affordable price, but I know ill be spending over 100$ USD.
Asus makes one fine board. But a good board will cost more. Just like anything else.
You're not paying extra for just a sound card. The P5N32E-SLI Plus board that I mentioned, which cost me $225+tax (yeah its not cheap), should have been named "Overclocking for Dummies". Seriously, you can use Asus' software (ie in windows) to set your BIOS to give you 120% overclock (from 1333fsb to 1600) without knowing a thing about overclocking. Just two or three clicks, a restart, and instant goodness. It also includes automatic BIOS recovery, so if your computer crashes due to overclocking, the BIOS will know when you restart, and reset itself to normal.
After you have your oc just the way you want it, the BIOS has two 'save slots' that you can use to save your settings. I suspect these settings would be erased in the event of battery failure, or CMOS reset, but I myself have made the BIOS recovery activate, and used the 'save slot' to load the last stable overclock.
As if that wasn't enough, this board also comes with another nice feature for those that aren't so dead set on getting that last Hertz from thier setup. AI N.O.S. This nifty addition to the BIOS will enable your computer to overclock up to 110% based on system activity. With this enabled, my 2.33GHz E6550 ran at 2.0GHz at idle and 2.5GHz under load (I had set it for 108%).
Plus, you get a nice 8-channel, multi-streaming high-definition sound card...
NOTE: Under NO circumstances should you attempt to overclock a computer if you don't know what you are doing. There is a risk of destroying your computer, but that risk is minimalized if you understand the 'proper' way to do it. The features on this board make overclocking simpler, but not necessarily foolproof. ALWAYS watch your temperatures when overclocking.
![Sol :sol: :sol:](/data/assets/smilies/sol.gif)
