Question Sudden fan rattling from AIO when the PC is under load
Wimpy Mike
14
The title pretty much says all. After downloading Apex, my fans (specifically the left one) on my AIO started to rattle. When I gently press down on the center, the noise goes away, but slowly returns if I play. And then now it rattles whenever I do basic stuff for a split second, like opening a browser, so I'm wondering if the initial load from launching Apex messed something up since I know it's pretty demanding.
What is there to oil?
Fan bearing is closed system, with lubricant inside the bearing. Depending on the bearing type and fan orientation, the lubricant can sweep out of the bearing in time, thus making the rattling sound.
Cross section of sleeve bearing (the cheapest bearing);
9885
Direct link if image doesn't load: https://www.sameskydevices.com/products/image/getimage/9885?typecode=m
Bearing lubricant is in-between the fan shaft and bearing housing. Once the lubricant is at lower level, shaft is starting to touch the bearing housing and you'll hear the rattle.
New fan is very cheap.
120mm fan starts from 5.5 bucks, pcpp: https://pcpartpicker.com/products/case-fan/#s=120&sort=price&page=1
And 140mm fan starts from 6 bucks, pcpp: https://pcpartpicker.com/products/case-fan/#s=140&sort=price
9885
I see, feels like a hassle since I have the deepcool aio which has rgb but I guess I gotta do it. So you think I was just unlucky with loading up Apex?
Hassle? 🤔
Is your system prebuilt? (Whereby you didn't install the AIO by yourself?) If so, then it may sound like a hassle, but instead is quite simple to do. Just follow the fan cables back to where they plug in (either one or to cables), disconnect them, unscrew the 4 screws at fan corners and remove the fan.
Installing new fan is essentially vice-versa, given you bought the very same fan you had. But if you bought different fan (e.g with no RGB eyecandy, where you'd loose some FPS :sweatsmile: ), then non-LED fan only has power cable that you can plug directly to MoBo for power.
Look for high static pressure fan. E.g 2.0 mmH2O or higher.
If you do have a prebuilt and/or doesn't want the fan replacement hassle, haul the PC to PC repair shop (or the shop from where you bought it) and pay them to replace the fan for you.
Hassle? 🤔
No I built it myself, it’s just I have had quite the problem with my PC if you look at my history so it’s just annoying. And the position is kind of awkward since it’s above the CPU.
How old is your AIO?
An AIO will fail in time.
Think 5 years.
If it is that old, there are some inexpensive air cooler replacements that are about as efficient as a 280 aio.
I don’t even want to think about that but it’s around 2 years old.
