G
Guest
Guest
I have a system with the following specs:
P120 (possibly overclocked from a lower Hz - not sure)
64 Mb EDO-RAM
1.6Gb + 750Mb + 350Mb drives
Win 95b, DUN 1.3, IE 5.5 or Win 95 (DOS 7) floppy
Just recently I have noticed a drop in performance. It is particularly
noticeable when I try to play MP3s - the software simply can't play them
properly, taking about 5 seconds to get through a second of music. Other
applications are also performing more slowly, too.
I am using a DOS MP3 player called MPXPLAY, nice powerful little thing.
However, I have the same problem with Sonique and Media Player so it's not
the software.
I am convinced it is nothing to do with Windows or other software, because
I can boot off a floppy and run MPXPLAY and the problem only gets
marginally better (always used to go better without Windows anyway).
I am also sure that there is nothing wrong with my disk/s. Firstly,
MPXPLAY offers a feature whereby you can load the entire MP3 into extended
memory before playing it, and secondly I have three hard drives and it
doesn't matter which drive I play the MP3 off.
My soundcard is fine, because I can play wavs or CDs fine. Nothing to do
with sound card memory because it always used to work fine.
RAM is a possibility, although the system reports that everything is fine.
No diagnostics (SiSoft) checks bring anything up - they all act as if
everything was normal.
According to my logic, that leaves the CPU, a P120. Again the system
doesn't report anything wrong, and I SiSoft benchmarks give a performance
rating of 120. I am told that this rating is accurate.
I have not manually changed any BIOS settings, but played with them
anyway, resetting them to BIOS then setup defaults. No difference.
I have run McAffee VirusScan with updated DATs and found nothing.
Does anyone have any ideas? Do you need more information about the system
or the problem?
64 Mb EDO-RAM
the software.
or the problem?
