Suddenly System Dead
jljordan
It was acting a bit weeird. Considered virus, 1/2 way through Norton AV scan System stops . Only blinking Monitor light. Replace Power Supply with identical , system boots up , but hangs after about 5 mins. Running Athlon 1600 with Windows XP pro, Event viewer keeps saying-- at every hang -- error acpi.sys . cannot do anything will not acd.have to hit button , seems a bit better without network, for a while it seems better without etx modem ( modem also says that there are a few commands it cant support-seems more than before..doesnt appeaer to ahng in safe mode.
all and any idea greatly appreciated
I'm sorry ... there's just not information in the post to ascertain the source of the problem.
Please list your complete system specifications, and a detailed observation of what the computer was doing before the lockups began (something a little more specific than "It was acting a bit weird", please.)
Problems like this typically occur because of 1.) a bad memory module, 2.) an older ACPI-BIOS that is incompatible with WinXP (which may require a flash), and/or to reinstall the OS with a Standard HAL and APM Power Management (sometimes with the APIC Interrupt Controller disabled, as well), 3.) or an incompatible/out-dated driver for a device, such as your modem, NIC card, or sound card.
Which one of these might apply in your situation (if any) ... that's for you to discover, at this point.
Here's a memory testing program. I can provide this for you, if nothing else:
<A HREF="http://www.memtest86.com/" target="_new">Memtest86</A>
Toejam31
<font color=red>First Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=17935" target="_new"><font color=green>Toejam31's Devastating Dalek Destroyer</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
__________________________________________________________
<font color=purple>"Some push the envelope. Some just lick it. And some can't find the flap."</font color=purple>
