Suggest better build ?
Horvat
221
I have Case and storage
but this is build
i5 7500
msi h270 g for carbon
hyperX fury black 2x8 gb 2400MhZ
evga supernova 650 g2
msi gtx 1070 armor
is this working good alltogehter , do you recommend anything else ?
i actually may go only for z270 because in future im thinking to go for some unlocked i7 kaby
il see about aftermarket cooler , thanx 😉
This inst very high end so there are a lot of "better" builds. Might I suggest you add a budget so you can get reasonable suggestions?
Everything you listed should work together just fine. You could even step down on the Power supply to 500-550watt range since you wont be overclocking your CPU.
1000€ , which psu ?
Why not consider a Ryzen 5 1600 and an X370 board? Whats your total budget, where will you be buying the parts, and what will you be using it for mostly?
The evga supernova 550 g2 would work fine. Lots to choose from here but that is a pretty good line of PSU's. That should cover the costs of stepping up to a 7600 which has better boosts speeds.
i do not prefer AMD soo much , ive had bad expiriences with them , but im open for suggestions , probbably from Alzashop.com
1000€ is budget
Europe unfortunatly
Its around 10€ cheaper
Ah ok, I also see that that site wants 245 euro's for that chip, and at that price its not quite as good of a deal, considering our cost in the US is around 200 euros. I will say that the Ryzen is a much more future proof chip, and probably platform as well when compared with LGA 1151 and the I5, but I get that you may be stuck on a budget. Also there will be times that those 6 cores and 12 threads will come be more beneficial than the 4 cores on the I5. It looks like you have a pretty solid build, you may want faster memory at around 3000, but otherwise it looks pretty good. What about storage? Are you going all flash based, or will you also be getting a hard drive?
I have 1tb 5400rpm , i plan to upgrade but not soo fast , in future
Honestly I know you're working with a bit of a buget, but it is very much worth including a 240GB SSD with that build, that, more than any other part will make your computer feel like a "new machine". I've included a few links below for ADATA drives in good, better, best order from top to bottom. I find ADATA to be the best priced for the storage and reliability that you get, also samsung, crucial, kingston and PNY make decent drives in my experience.
https://www.alzashop.com/adata-premier-sp550-240gb-d2921603.htm?catid=18845887
https://www.alzashop.com/adata-ultimate-su800-m-2-2280-256-gigabytes-d4591936.htm?catid=18845887
https://www.alzashop.com/adata-xpg-sx7000-ssd-256gb-d4842706.htm?catid=18845887
Ultimate SU800 M.2 2280 il be getting probbably this one , but not as fast , probbably half of the year after buying the new rig
