Henry1990 :
1) Do I really need a UPS to keep my computer safe, is the occasional sudden shutdown to computers really that bad? If it's not then I'll just use a surge protector since true sine wave UPS's are too expensive for me.
2) What specifications for a surge protector should I get for an 850W power supply?
3) And is an RJ45 surge protector really necessary, I have a modem to router to computer setup, so would I have the surge protector between the modem/router or router/computer?
4) Does the RJ45 surge protector decrease the connection speed significantly? (I'm a gamer and download a lot of movies)
1) That UPS has only one function – to provide temporary power during voltage drops or blackouts. A majority will preach other functions. And those others functions do exist – at near-zero levels. A near-zero function is a 100% function in sales brochures. In the real world, we also call that a myth. Only function that a UPS actually does is temporary power.
Why are power interruptions problematic? It results in lost data. Power loss only causes hardware damage in myths. Nobody define the component harmed by power off because that damage is only promoted by myths. Power loss only puts unsaved data at risk.
However power loss may be preceded by a surge. A plug-in UPS does not claim surge protection (which is found in larger building wide systems). Don’t take anybody’s word for it. Read manufacturer spec numbers for transient protection. See its joules number? Near zero. But enough above zero so that the naïve will claim it provides 100% surge protection.
Pure sine wave does nothing for any electronics. All electronics must be so robust that even 270 volts spikes from the cheapest (and ‘dirtiest’) UPS is considered ideal power. That sine wave myth is popular among those who do not know what every electronics supply must make completely irrelevant. Whereas a cheap UPS can be harmful to a small electric motor or power strip protector, that same UPS electricity is ideal for all properly designed electronics.
2) A surge protector is only as effective as its earth ground. Any protector adjacent to the computer does not claim protection. And can even earth surges destructively through that computer. Transient protection is always about the protector that actually does protection – one ‘whole house’ protector. If you computer needs protection, then so does the stove, furnace, bathroom GFCIs, and smoke detectors. The only protector that actually does protection comes from companies that are far more responsible. Every effective protector has what is always necessary – that short and dedicated connection to earth. A surge protector is only as effective as its connection to single point ground.
Install a surge protector so that direct lightning strikes cause no damage even to the protector. A solution that costs tens or 100 times less money. And does not have the massive profit margins that generate myths. For example, your telco’s switching computer is connected to overhead wires all over town. Suffer 100 surges with every thunderstorm. And must never have damage. How often is your town without phone service for four days after a thunderstorm? Never.
Telcos use no plug-in protectors. Telcos avoid damage so often associated with a plug-in protector or UPS. Effective protectors harmlessly earth all destructive type of surges – even lightning – and remain functional. Protection is always about where energy dissipates. Either energy dissipates harmlessly in earth. Or that surge is inside the building hunting for earth destructively via appliances. Any facility that can never suffer damage puts the protector within feet of earth ground. In telco facilities, the protector is up to 50 meters distant from electronics. That separation increases protection.
You need the same solution that costs tens or 100 times less.
Destructive surges are hundreds of thousands of jouiles. How many joules does that UPS absorb? Hundreds? IOW it is near-zero surge protection. Just large enough to get the naïve to hype 100% protection in a sales brochure.
3) RJ-45 protectors do what? If it stops or blocks a surge, then you have no Ethernet. Why would your computer and modem be damaged? First a surge builds a current path from cloud, through your electronics, then out some other wire to earth. Nothing stops that current. Absolutely nothing. Either you earth that current before it enters the building. Or that current hunts for earth via electronics. The effective protector connects within feet to earth. Ineffective protector hope you never learn that essential requirement.
RJ-45 already has significant protection. Typically rated to withstand at least 2000 volts. What can overwhelm the protection? Any current that is seeking earth ground. In destructive types of surges, voltage increases as necessary to overwhelm that 2000+ volt protection IF you do not earth that current where wires enter the building.
Did you know all phone lines and TV cables already have superior (the best) surge protection? Even required by laws, codes, and regulations. However, that protector is only as effective as earth ground that you are responsible for providing. If you (or your agent – the electrician) did not properly install that earthing, then superior protectors are compromised.
4) You have assumed Ethernet gets slower. It doesn’t. Either each Ethernet packet is delivered intact. Or Ethernet keeps sending the same packet until it gives up. Ethernet does not work like WiFi. Wifi will lower speeds as necessary until data can be transferred. Ethernet (RJ-45 connector) does not do that.
