Hi everyone, I'm thinking of changing the fan from my "Cooler Master GX 650W" source.
However, the connector is 2-pin. I can not find fans of 2 pins here (I'm living in Brazil), only 3 pins.
Would it be any problem for me to cut the cable from the original 2-pin fan and couple it with a 3-pin molex?
Taking advantage of the occasion, should I use a fan with high pressure or high CFM? Maybe this Akasa Viper is enough?
Sorry for my English..
Thank you all.
Specifications:
- Dimension 120 x 120 x 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 ~ 1900rpm
- Airflow 83.63 CFM (141.75 m3 / h)
- Noise level 6.9 ~ 28.9 dB9A)
- Current 0.17A
- Pressure 2.64 mm-H2O
- Service life 50,000 / hrs
- Double Bearing Ball Bearing
- 4-pin PWM connector (with RPM sensor)
- Voltage 12V
Thank you all.
Specifications:
- Current 0.17A
- Voltage 12V
