Hello everyone,
I recently upgraded from an i5 7500 to a 3700x. Since I didn't have anything to remove the thermal paste from my CPU at the time, I decided to fit the stock cooler onto my 3700x for now. I was wondering whether it'd be worth it for me to switch from the Wraith Prism to the Hyper 212 which is still attached to my old motherboard. I assume the main difference would be that it will be a lot more quiet but I heard top-down coolers also have their advantages. Will my temperatures be lower with the 212 as well? I don't mind switching the coolers so if it gives a big enough advantage I will probably switch them.
Little side note, I also heard some people had issues with the removal process of the AMD stock coolers where the cooler would be hard-stuck to the CPU because of the thermal paste. Is this something I need to look out for if I do decide to switch the cooler?
Thanks in advance
Thanks in advance
