Hey guys, not sure if I got the right forum for this.
Basically, in the build I'm about to do I'll have an ASUS Mobo w/ RGB and RGB on the GPU and RAM, along with some RGB strips. I also have a Corsair case (460x) and a Corsair radiator (Hydro Series H115i) with RGB. I would like, if possible, to be able to sync all the RGB elements together for cool themes and active light displays.
Through my light research, it seems this will be harder than I anticipated. Are there any 'easy' solutions to this, or would my only option be to replace all the fans with ASUS Aura compatible (I think Cooler Master makes them) ones?
