You can connect pretty much any 3 pin fan on teh SYS_Fan header
located at the bottom of your board.
If you're asking if you can use the header to power a single case intake or exhaust fan, then yes, you can do so without any issues. You might want to list your case's layout in order for us to gauge the optimum placement of your case fan.
