Question System bluescreens randomly
Dec 23, 2021
6
Randomly while using my computer, I get bluescreened and get this error message:
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000101 (0x000000000000000a, 0x0000000000000000, 0xffffcd8049760180, 0x0000000000000004). A dump was saved in: C:\Windows\Minidumps\102522-12187-01.dmp. Report Id: 0da78f6d-4e25-4f9c-ac20-22a14608e8ca.
It usually happens when playing or launching games, but also sometimes while idling or doing nothing.
Specs and when they were bought;
MOTHERBOARD - Z690-F GAMING WIFI (2022)
GPU - MSI GeForce GTX 1080 8GB Gaming X (2016)
CPU - Intel Core i7-12700K (2022)
CPU COOLER - NZXT Kraken X53 CPU Cooler (2022)
RAM - Corsair Vengeance DDR5 5600MHz 32GB (2022)
SSD - Samsung 970 EVO 500GB NVMe M.2 PSU - (2021)
EVGA GQ 650W Hybrid Modular 80+ PSU (2016)
MOUSEPAD - HyperX Fury S XL
MOUSE - Logitech Pro X Superlight
KEYBOARD - Corsair Gaming K95 RGB Platinum
MONITOR - BenQ XL2411Z (144hz)
MIC - Blue Yeti
Got the problem after installing my new parts bought in (2022) so im suspecting the problem might be from that/them.
Let me know if you need more information and ill provide it as fast as i can.
I'm not an expert, but in a similar situation. I'd try to run all kinds of tests first: Windows own tests like SFC, CHKDSK and others like OCCT, Prime95, memTest86 etc.
Have already done half of those.
Opened pc earlier today, pressed everything firmly in place incase anything was loose, nothing was (that i could feel atleast) But one of my ssd's power cable wasnt connected idk if that might have anything to do with it
MIC - Blue Yeti
Did you do a fresh install of Windows after parts change?
how would you go about reinstalling windows? is there a way to install it without losing files? and can i do it without a usb stick? i dont have a usb stick with enough storage. And yes my RAM installed in the correct slots :)
Havent bluescreened in a while though now, but reinstalling windows or even downloading windows 11 cannot do any harm anyway
