[SOLVED] System Boots, doesn't load SSD automatically and goes to BIOS
Apr 10, 2021
The system starts then it goes to the bios area and doesn't automatically load SSD. Whenever it loads SSD everything is so slow it just kinda crashes after loading the whole window screen for a minute. ALSO if I stay in the bios area and navigate around it is very very very very slow. I don't think SSD issue because the BIOS is also slow.
TLDR: bios slow ssd slow pc crashes after booting
I'd say make a bootable USB Flash drive of Ultimate Boot CD. Then unplug the SSD and try booting off it. You could also make an Ubuntu Live USB. I just suggest UBCD. Because if it doesn't boot. It has diagnostics you may run. Including the all important memtest86.
The boot option for UBCD is Parted Magic. The memory test is under Memory. I use RUFUS to create a bootable installer. The following link will give you more details on how to get going.
What is the backstory on this?
Full parts list, did it ever work, what was the last thing you did before this happened....
Details, please.
