System build help (parts picked)
cakester5
Commendable
Dec 25, 2016
24
I need to know if these parts would work together and if they don't, other parts to use.
I know this seems like a big ask, but this is going to be my first build and i don't want to stuff it up. But the main thing here is too tell me if the parts would work together. You don't have to make me an entirely new pc.
All the help is appreciated
https://au.pcpartpicker.com/list/rvhtr7
Also, i know there isn't an os or storage, but i'm getting those for free
1tb hard drive and 64 bit windows
thanks for the help
I did look abit further and found this motherboard in the next build,but it isn't enough to get a substantially better gpu in,it does give space for an ssd,
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor ($265.00 @ PCCaseGear)
CPU Cooler: Cooler Master Hyper 103 43.1 CFM CPU Cooler ($29.00 @ Centre Com)
Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard ($134.00 @ Scorptec)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($148.50 @ Newegg Australia)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive ($93.00 @ Shopping Express)
Video Card: XFX...
This build will work but I would advise that you go for this: https://au.pcpartpicker.com/list/
This is slightly more and will perform much better. The AMD CPU is a bad choice and spending 100 on a case in a 1000 build is not justifiable
this is a solid build.... in 2013.
this will outperform the system by a mile...or 4
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor ($285.00 @ PLE Computers)
Motherboard: Asus PRIME B250M-PLUS Micro ATX LGA1151 Motherboard ($139.00 @ Mwave Australia)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($144.10 @ Newegg Australia)
Video Card: Asus Radeon RX 470 4GB STRIX Video Card ($299.00 @ PCCaseGear)
Case: Inwin 703 BLACK ATX Mid Tower Case ($79.00 @ Mwave Australia)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($85.00 @ Shopping Express)
Total: $1031.10
Generated by PCPartPicker 2017-01-22 11:18 AEDT+1100
How is the amd cpu a bad choice? Also, this isn't a 1000 build. It's a bit lower then 1300 if you count the other parts
I have asked a friend who is good a pc building too build me one that would be good for what i want to do and he built this.
https://au.pcpartpicker.com/list/hB2Rqk After some research i replaced some parts and it turned into this: https://au.pcpartpicker.com/list/rvhtr7
Should i go with the first or second?
Here are some figures showing the 1070 in my build vs the 1050 to in yours: GeForce-GTX-1070-vs-GeForce-GTX-1050-Ti
As you can see the 1070 is much more powerful and I have managed to put it in the same budget as you
- the SuperNOVA Nex is pretty poor of a PSU for that price.
- the 1050Ti is pretty weak in terms of performance
- H170 boards need a BIOS update to work with Intel's 7x00 CPUs. So you'll need a H270/B250 board
- the case is kinda pricy. Looks good yes. But kinda pricy.
- the cooler is a nice gimmick. However 35$ make a difference with your budget. I suggest going with the stock cooler for now. You can replace the cooler later on.
@TheSenpaiOfTech you didn't list any build...
You didn't give me a build
Earlier on i did, can you not see it?
It is nothing. You need to get the url of the build in the top left.
https://au.pcpartpicker.com/list/FjpKkT Is my build
Got rid of the cooler (not over clocking any way), don't care about the case's cost and I will get a new motherboard.
The psu is a 650w 80plus gold, how is that bad?
For a 1300 build, is the gpu really bad?
Also, it says that my cpu can't handle the voltage of the ram. If you go to the bottom of this https://au.pcpartpicker.com/list/VZmLf8
What does that mean?
Why is everything so tiny?
It has a crap psu in it so it's not.You can't just give up all quality just to get a better gpu in it.
If choosing the I5 7500 or other Kaby Lake would i wait for boards with the right chipsets to be displayed in the pcpartpicker or look at the shops for best compatibility.
Something like this,
https://www.mwave.com.au/product/asrock-z270pro4-lga-1151-atx-motherboard-ab94331
Looked at your own build and the motherboard you chose is using ddr3 which you don't want so although probably cheap not the right one.
its not that bad and for about 10 more you could get a better one anyway
For the gpu is 4gb becoming about the standard,but it depends on the resolution you play at too,also what games.
650W --> maximum rated wattage output
Gold --> efficiency rating, how much power is wasted by the PSU.
Both says nothing about the quality of a PSU.
It's like saying your shoes are size 13 and brown - doesn't tell you anything about the quality of your shoes.
The 1050Ti is a good card at 720p. At 1080p you're looking at mid-settings.
As for TheSenpaiOfTechs build:
Terrible PSU.
Wouldn't go for an ITX 1070 as they're drawn to thermal throttling.
Furthermore an i5-6400 can bottleneck a 1070.
However the general idea is pretty good.
An i5-6500 + a better PSU might make room for a GTX1060/Rx480
Sorry for my build, I posted it as a point more than a guided build. I agree with you completely
Latest posts
