System build help (parts picked)
cakester5
Commendable
Dec 25, 2016
24
I need to know if these parts would work together and if they don't, other parts to use.
I know this seems like a big ask, but this is going to be my first build and i don't want to stuff it up. But the main thing here is too tell me if the parts would work together. You don't have to make me an entirely new pc.
All the help is appreciated
https://au.pcpartpicker.com/list/rvhtr7
Also, i know there isn't an os or storage, but i'm getting those for free
1tb hard drive and 64 bit windows
thanks for the help
I did look abit further and found this motherboard in the next build,but it isn't enough to get a substantially better gpu in,it does give space for an ssd,
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor ($265.00 @ PCCaseGear)
CPU Cooler: Cooler Master Hyper 103 43.1 CFM CPU Cooler ($29.00 @ Centre Com)
Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard ($134.00 @ Scorptec)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($148.50 @ Newegg Australia)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive ($93.00 @ Shopping Express)
Video Card: XFX...
When using the motherboard above could you look at something like this,
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler ($35.00 @ Mwave Australia)
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard ($189.00)
Video Card: XFX Radeon RX 480 4GB RS Video Card ($299.00 @ PCCaseGear)
Case: Cooler Master CM 590 III (Black) ATX Mid Tower Case ($69.00 @ IJK)
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified Semi-Modular ATX Power Supply ($99.00 @ Umart)
Total: $1104.50
Generated by PCPartPicker 2017-01-22 23:53 AEDT+1100
the motherboard in here is just a random picked one to add the price of this one,
https://www.mwave.com.au/product/asrock-z270pro4-lga-1151-atx-motherboard-ab94331
i use this board because it will make it possible for the cpu to run all cores at max turbo and run that 2400mhz ram at that speeed. That's why i also still use the cooler,with all cores at max turbo the cpu will get hotter.
This psu should still be fine with this build,
https://au.pcpartpicker.com/product/FQ648d/corsair-power-supply-cp9020101na
is cheaper.
I only looked at one seller and this board was just abit more expensive than H270 or B250 boards there so imo worth it. Haven't looked deeply into it since these chipsets aren't in the pcpartpicker yet. You would have to go through the entire range of shops and all that they offer to get to cheaper boards.
Case: Cooler Master N200 MicroATX Mini Tower Case ($58.30 @ Skycomp Technology)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($85.00 @ Shopping Express)
Total: $1111.80
Generated by PCPartPicker 2017-01-23 00:26 AEDT+1100
