[citation][nom]sublifer[/nom]I do admit that multi-card has improved...
...but for the bargain PC where you look for bang for buck, that $150-200 would have been much better spent elsewhere..[/citation]
I'm going to call you on this one. Where could we have spent it better for a superior gaming result?
[citation][nom]sublifer[/nom]I know the q6600 is a good buy, but its better if you get the g0... when you got the cpu (or pulled it from stock) and realized it wasn't the g0, why didn't you get a different one?[/citation]
Because we're doing real-world testing, not cherry picking every component so we have a result you can only expect to get when everything is perfect. In the real-world, everything is NOT perfect. I think the +1 GHz overclock showed what can be expected from the Q6600 in the worst case scenario, and the results were pretty damn good even though we didn't break any records. I'd rather show people worst case scanario than a best-case scenario they can only reach if they're extremely lucky.
[citation][nom]sublifer[/nom]My biggest cpu disappointment was the e7200 though. As I mentioned above, the money not spent on the 2nd card would have been great to get a better processor.[/citation]
I see your point, I just disagree. We had no way of knowing the E7200 wouldn't play nice with the MSI board; if there wasn't an unforeseeable glitch, the E7200s are known to overclock very high, just as high as more expensive processors. So from a overclocking standpoint I think we're better off with a cheaper CPU that overclocks well paired with dual videocards, rather than a stronger CPU that should overclock in the same range with a single videocard.
[citation][nom]sublifer[/nom]I'm not saying all the choices were horrible, and as other noted, seeing this does point out in some cases what not to get... I just think money could have been put to better use in the mid and low-end builds.[/citation]
I appreciate that, and I don't think you're opinions are without merit; I just disagree with some of them. But I do appreciate your opinion and especially the honorable way you raise your concerns, rather than trash-talking like some whiney buffoon. This is the kind of exchange of ideas that help everyone.
