Other than power consumption, for gaming, the FX-8350 here did about as well as the previous build's Intel CPU. The only times where it truly did worse, according to these benchmarks, was when it was already far above 60FPS anyway. As I've said before, measuring in frame latency would give a much more accurate show of things, but for gaming and going just by the gaming benchmarks from this article, the FX-8350 kept up excellently in performance, albeit suffering badly in power consumption (which is easily rectified by simply disabling one core per module since there really aren't any games where a 4M/4C FX-8350@4.3GHz (could go a little higher thanks to the extra thermal headroom while still dropping power consumption) is weak. For the FX-6300, slightly higher frequency could easily offset the (then) one fewer cores and the much lower price could put some budget elsewhere.
Thanks for giving Vishera a try, Toms, but you could have done better with it if you wanted to.
[citation][nom]JonnyDough[/nom]It's great that you built a worse PC for $1000 than you did back in August...But I'd rather see the benchmarks vs the $500 build so I know if that extra $500 is worth it or not. Although I think MOST of us know that between $500-650 is about all one should really spend these days on a new gaming system.[/citation]
There will undoubtedly be such comparative benchmarks in the follow-up to the last SBM build this month.
Also, there's no bad reason for spending more than $500-650 on a gaming machine. It's not until far over $1000 where you start to run out of extra performance for extra money.
