System Builder Marathon, Sept. 2011: $1000 Enthusiast PC
Mobo is overpriced, and so is ram. The cost of the 460's you could equally get 2x6870s. PSU kinda sucks, for $1000 you can at least save else where (IE RAM+MB) and still get the Antec HCG750, while also getting 2x6870. Just personal opinion.
Why all the overpriced components? This is bad...
Off the top of my head,
1. There are a number of decent Z68 motherboards for around $130.
2. Hyper 212+ costs $30
3. A Corsair 2x4GB 1600MHz CL9 kit costs $50
4. There are plenty of good 1TB drives for $55
5. Antec Earthwatts 650W costs around $60
And don't give me any crap about price increases over the past month. All of these have remained the same for the past 2 months.
I'd prefer either a larger ssd or none, 30GB would be annoying.
At the $1000 mark i'd opt for 8GB of ram, no ssd and a better hdd. And not a microATX.
Also why isn't micro stuttering mentioned? If i remember correctly, these cards have issues with it.
Guess that was mostly negative stuff, i liked reading it anyway though, keep em coming.
I like this system a lot better than yesterday's. A more balanced build. Kudos! It's always interesting to see similar setups and how they compare, for instance in this case the 6850s versus the 460s. Glad you are switching it up. I'd say you were right on the CPU front to stick with the 2500K. Nice work overclocking those GTX 460s and the CPU. And I'd say this is an appropriate chose of computer case for this kind of setup. I had my reservations about using Antec's cheapest "gaming" enclosure for the $2000 build, but this is spot on.
Nice PSU as well. I do wonder though why you didn't go with the CX600V2, as it's 80+ Certified and sells for the same price as the CX600 (actually, a $10 MIR right now so $59.99).
Also, and this isn't a critique but purely personal preference, I would probably forego the SSD for myself and stick with a cheap HDD like a WD Green. Loading times aren't that important to me; I'm willing to wait a few more seconds if it means I can put the $ I saved towards a better mobo, HSF, or better non-reference GPU cards. Call me crazy but I'm willing to wait a bit longer, as well as not having to worry about my OS drive wearing out, in order to get very slightly better performance/temps. I realize that drive performance is an important metric for most people though so I'm glad you are incorporating that into these modern builds. Can't wait to see the $500 one :)
interestingly still going for dual mid-range cards despite the whole microstuttering article you guys wrote up recommending against dual mid range cards. Better motherboard than the high end build, at least its not Gigabyte. A 30GB SSD is completely pointless, i was unaware they even made them that small. But i suppose its something different to you usual, there are so many possibilities with a mid range build. Will be more interesting to see what you can fit into the lower end build.
I wouldn't had chosen a pair of gtx 460 because those are not quite power efficient as pair of gtx 560 non TI would be, I would had picked up to two HDD over a SSD. Overall I like this dynamic "System Builder Marathon" that uses TH, It helps you to take better decisions.
I would get a different: motherboard (not a mAtx), hdd (samsung spinpoint 1tb), case (I don't like the look of this case) and maby a different cooler (212+)
other than that, its a realy nice build
[citation][nom]_Pez_[/nom]I wouldn't had chosen a pair of gtx 460 because those are not quite power efficient as pair of gtx 560 non TI would be, I would had picked up to two HDD over a SSD. Overall I like this dynamic "System Builder Marathon" that uses TH, It helps you to take better decisions.[/citation]
I want to delete this comment, I made some mistakes with grammar. If I had chosen, I wouldn't have gotten a pair of ... so embarrassing..
[citation][nom]_Pez_[/nom]I want to delete this comment, I made some mistakes with grammar. If I had chosen, I wouldn't have gotten a pair of ... so embarrassing..[/citation]
YOU ARE FIRED!
[citation][nom]Kridian[/nom]Where exactly on this site do they announce the winners of these contests?[/citation]
In the news section. Every single quarter.
[citation][nom]iam2thecrowe[/nom]interestingly still going for dual mid-range cards despite the whole microstuttering article you guys wrote up recommending against dual mid range cards. Better motherboard than the high end build, at least its not Gigabyte. A 30GB SSD is completely pointless, i was unaware they even made them that small. But i suppose its something different to you usual, there are so many possibilities with a mid range build. Will be more interesting to see what you can fit into the lower end build.[/citation]
Don claims he's not affected by micro-stuttering. Indeed, everyone's sensitivity to this seems to be different.
I don't think I learned anything from the choices made in this one. Once I loaded a few programs, I was hitting the limit on a 64GB SSD, so there's no way I'd ever put a miniscule 30GB SSD into a system (except possibly as swap space).
That is specifically not to imply that I could build a $1K system offering better performance, just that this one didn't offer any of the revelations often seen in SBM builds.
jtt283 the size of Win7 64 and Win7 32 are quite significant. 32 bit can actually fit on a 30GB np.
Also my Win7 64 bit Home Premium fits on my Intel X-25V 40 GB SSD, with Office and Chrome/Firefox with 8 GB to spare. So it's really not too bad.
I remember reading on the Corsair site that the CX- ("Builder") series of PSUs are rated for an ambient temp of 30*C. That's not exactly a good idea in warm regions or in a case in which the PSU doesn't have a fresh supply of air, as the inside temp can easily cross 30*C.
Maybe the Corsair GS600 would be a better choice? :O
A couple questions as I look to build a new machine...
Why not go with a Z68 and get the advantage of QuickSync? The cost is virtually the same if you go with your own Gigabyte Z68XP-UD3 recommendation for $150, especially if you ditch the SSD which seems too small to be worthwhile ({Danny Vermin voice} I did a 30GB partition once. Once!)
What are the thoughts on getting a 6970 2GB instead of twin 460's? Wouldn't the performance be comparable in the near term and provide more upside down the road (by crossfiring later)?
Nice mix up!
Good to see you try different approaches to the builds! cant complain as it helps show what different hardware performs like without having to spend your own money!
I would use this build, with the change of dropping the SSD, using a 1TB HDD and spending the savings on a full atx Mobo (Which can be had for the same price as your mATX board) 8GB Ram and 2 6870 with better PSU ( The Corsair is a good PSU but not for Xfire as you mention)
These last two builds have been pretty bad, I must say. The AsRock P67 Extreme4 is better than the EVGA Micro SLI, the Samsung Spinpoint F3 1TB is quieter and faster than the Caviar 750GB, not to mention the same price. The SSD is overpriced and slow, and the Power Supply is not a very good unit at that price. For $70, you're better off getting an Antec HCG-620, a Seasonic S12II 620, or an Antec NEO ECO 620C. The heatsink, why did you skimp on it? You're only saving $10 and getting a huge downgrade in heat dissipation...
I think they use parts they have lying around, i don't think they actually try to build a sweet setup, they are just trying to clear storage space.
[citation][nom]jtt283[/nom]I don't think I learned anything from the choices made in this one. Once I loaded a few programs, I was hitting the limit on a 64GB SSD, so there's no way I'd ever put a miniscule 30GB SSD into a system (except possibly as swap space). That is specifically not to imply that I could build a $1K system offering better performance, just that this one didn't offer any of the revelations often seen in SBM builds.[/citation]
How is 64gb not big enough to use as a boot drive? I was running 2x30gb in raid0 but one of the drives died so Ive been stuck with 30gb for months now and havent run into any space issues. I install everything but games to it and still have 9gb free. I have 2 raid arrays of regular drives where I install my games and store my files..
This build really should have used an inexpensive Z68 chipset to enable SSD caching with an SSD this small, and a fast single graphics card. Far too much $$ is spent on graphics cards and benchmarks should be adjusted to somewhat de-emphasize them on lower-budget builds so as to not ruin the rest of the desktop experience, as well as take micro-stuttering into account as a penalty on multi-GPU setups.
Benchmarks could be more indicative if framerates above 60fps were discounted in real games, since it doesn't matter if the framerate is 80fps or 130fps. A formula should be applied so that this is quantifiable.
The performance of the build should also be tied to the expected native resolution, so that performance of the $1000 build isn't tied to a ridiculous 2560x1600 resolution. It makes sense for the $2k build but not this one.
All of these things would allow you to justify a single-GPU system which would free up $$ a more capable motherboard and SSD, leading to a more well-rounded build.
win8! systems great !Hope it works better than the original defy
Should show minimum FPS with benchmarks instead of a subjective opinion on micro-stuttering. Who know, you might discover micro-stuttering to be less/more of an issue in certain configurations!
You guys sort of shot yourselves in the foot with that micro-stuttering article. Now every time I see a SLI/CF setup, I question its FPS variance. :)
