Hi all,
I just finished a new build (spec at end of post) and I am currently testing. I am worried about my temps.
My core 1 idles at 53 with the others ranging between 40-45c. At 100% load (AIDA64) the cores all run at around 60-64 (at stock specs). Was hoping for better considering the aftermarket cooler. Not a good place to start overclocking from! Also noted that even at 62-64 the CPU fan was only at around 50%.
The GPU is also running a bit high. It got to 81c by the end of the latest FurMark test (though oddly GPU fan was only at around 50% even at 81c??),
I am suspecting the following culprits:
- I removed the side case fan in order to have place for the CPU cooler. I installed an additional back fan to make good for this. Has this screwed up the case's airflow too much?
- For the thermal paste, I tried to use the pea method. However too much liquid came out the moment I touched the tube (the cooler master stuff is very watery). The dose then was say 1.5 of what I consider to be pea sized. I removed some of it, however this meant smudging it. Should have cleaned and reapplied but instead I shifted to an alternative method I read about - the square method. This consists of making a small, very thin and very flat square. I did check the chip for finger prints before applying the thermal paste - it was immaculate.
Any thoughts? are these temps too far from the mean?
ps: ambient temp here is 29c atm.
Specs:
Case: Xclio A380
Intel Core i5-3570K 3.40GHz, , Gigabyte Z77X-D3H Intel Z77, Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz, HIS HD 7950 IceQ BOOST 3072MB**Voltage Unlocked**, Cooler Master Hyper 212 Evo CPU Cooler, Samsung 256GB SSD 840 PRO SATA 6Gb/s
Specs:
Case: Xclio A380
