System Fan Header Issue
jayman9813
56
When I plug my case fan into the system fan header on the mobo, it won't boot up. The light on gpu and cpu fan will turn on for just a sec and spin then nothing after. But if I unplug my fan from the header then everything works. Is this a motherboard issue or what? Cause I have my fans running now, just always 100% running cause I can't control them since they're not connected to mobo. Any help is appreciated.
My mobo is GIGABYTE GA-H81M-H LGA 1150 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128693&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Motherboards+-+Intel-_-N82E16813128693&gclid=Cj0KEQiA_fy0BRCwiLaQ5-iFgpwBEiQA884sOeCUeUWzzn5oue_sUHrTZv4wjOddW5s-qIL5SvHvyn4aAv768P8HAQ&gclsrc=aw.ds
The fans are, http://www.amazon.com/Corsair-Series-AF120-Edition-Airflow/dp/B00F6S13DE
okay so in the manual it says that 3 pins = sense. Does that even mean the fans will spin? I have tried both of the other fans and same result.
yes it should spin. the speed control would be on the 4pin. actually now that I think about it, it should go full speed when you plug it in with a 3 pin fan.
Exactly, that's what I was thinking. So what's the problem? THis is how i had it connected, 1st pin nothing then the right 3 pins full with fan = light up, no spinning. I tried this, 3 pins from left full and last, 4th pin empty and nothing happens.
Yes, when 4th pin is empty upside down and right side up, the fan doesn't light up or spin. ANd yes the system fan header on the other side of the mobo
