system get shut down with ups while gaming
gurparkash
38
i am playing watch dogs on my system and seems it getting much load on system even game is running smoothly. i have power control(ups) with my system but when electric get off while gaming computer get shut down and one. it failed to save computer from shut down on high games as watch dogs or 2 and after it get shut down all of saved game get reset and i have to play from start(only watch dogs 2 reset not other). what should i do for solve this.
My system spec is:-
CPU: FX-6300 3.5 ghz black edition
Motherboard: Gigabyte 72LMT-S2PT
Ram: 8GB
HDD: 1TB
GPU: GTX1050Ti 4GB DDR5
PSU model:-Zebronic ZEB-N450W(DSATA)
Economy series (20=4 pin)
UPS:-iball UPS-621V
OS: Windows 10 64 bit version 1703(as i mentioned already).
Monitor: 22" meaning 1080p gaming
UPS's are designed to keep a computer up and running for either a safe shutdown or long enough to complete and save important work. They're really not designed for the amount of power draw required for gaming. Your UPS is only rated for 350W which is right on the edge of what your systems is drawing. If your power goes out you should just safely shut down your computer. It can't handle the power draw of a fully loaded CPU and GPU.
