System has recovered from a serious error problem !
jaigopal
18
I got this message when i switched on my pc saying
"the system has recovered from a serious error"
with the following report on the eventvwr
Error code 1000008e, parameter1 c0000005, parameter2 805398b3, parameter3 b6b8f9e8, parameter4 00000000.
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 31 30 30 30 30 30 38 1000008
0020: 65 20 20 50 61 72 61 6d e Param
0028: 65 74 65 72 73 20 63 30 eters c0
0030: 30 30 30 30 30 35 2c 20 000005,
0038: 38 30 35 33 39 38 62 33 805398b3
0040: 2c 20 62 36 62 38 66 39 , b6b8f9
0048: 65 38 2c 20 30 30 30 30 e8, 0000
0050: 30 30 30 30 0000
my pc specs are
AMD athlon II x2 240 processor @ 2.8 GHz
Asus M2N68AM-plus mobo
2x1GB transcend DDR2 ram
Windows xp profession sp2
with a onboard nvidia graphics
and a 450W power supply
My pc kept crashing sometimes back a week ago when i had my ati radeon HD4650 graphic card so i removed it from my pc , did a clean installation of windows once again , updated my mobo bios to the latest available and also changed the CMOS battery . So after this i was just using the onboard graphics and suddenly now i got this message which makes me go mad ! please help me with this problem . thanks in advance.
P.S. yesterday the PC went still , with no beeps sounds and nothing at startup with just the power LED glowing and the bios too didnt load up , so i removed the battery and RAMS and switched it on and it started to beep and again i inserted everything and it worked ! but now getting this problem 🙁
it also got the following error report in event viewer
Let's try (1) stick of RAM and run Prime95 + Blend, monitor the temps with HW Monitor. Try (1) stick for each running an hour, the temps especially for the first 15 minutes must be monitored for a 'spike.'
Prime95 - http://www.mersenne.org/freesoft/
Also, I'll post the manual settings for your RAM. Please provide a link to you EXACT set of RAM otherwise I need screenshot of the 'SPD' tab from CPU-z - http://www.cpuid.com/softwares/cpu-z.html
Thanks for you assistance jaquith ! i removed the that ntoskrnl.exe and win32k.sys files and replaced them with new ones from the OS disk and also did a update for my Graphic card ! now everything works fine ! thanks for the help you did and I'll contact you in future if i need your assistance :)
