Hi guys, I'm having an intermittent issue with my pc freezing. Typical symptoms are a sudden loss of control where I can move the mouse but cant open any new programs or shutdown the computer, If I have task manager open it will show the cpu usage graph as frozen. The problem can manifest itself in days or weeks which makes it very difficult to troubleshoot. I've also had the occasional blue screen (these are rare), on the previous one I checked the memory dump and it had memory corruption error. Only the bluescreens seem to leave any kind of trace as to what happened.
The instability is not load dependant, most of the freezing has been on the desktop with light loads, a couple were under heavy loads. Temperatures for both CPU and GPU are kept below 70C under heavy loads so this isn't a cooling issue.
My first thought was a memory issue, I have 4 x 8GB Corsair Vengeance 3000mhz modules. The pc does seem to fail more frequently in this configuration. However I have tried a different 16GB Corsair Vengeance kit from another pc that I know works fine and I still had issues with that.
I tried re-installing Windows 10 on another disk but same symptoms. Any ideas what this is most likely to be? I'm at a bit of a loss, thanks.
My specs are:
Cpu: Core i9 10850K @ 4.5Ghz
Cooler: Asus Strix LC 240mm
Motherboard: Gigabyte Z490 Vision G
Ram: 32GB Corsair Vengeance 3000mhz
GPU: Palit Nvidia 3080
SSD: 2 x 1TB nvme, 2 x 500GB sata
HDD: 2 x 4TB
PSU: Seasonic Focus GX Gold 1000W
Case: Meshify C
My specs are:
HDD: 2 x 4TB
Case: Meshify C
