[SOLVED] System interrupts CPU usage spikes
Sep 12, 2020
So my PC was behaving a little slow when i was unpacking a win rar file. I've been experiencing lots of lag spikes ever since i got my motherboard replaced a little while ago. many people on the forum said that it's the spikes in cpu usage caused by task manager. but please explain this. I've updated all my drivers. Is this a hard ware issue ?
My PC Specs-
Ryzen 5 2400G
Corsair 16gb ram
Zotac GTX1050ti Mini
550W Corsair VS550 powers supply
Gigabyte b450m-h motherboard.
View: https://imgur.com/a/NSW7xDm
Please help me out !
Is this a repeat of another post?
Your CPU usage will spike noticeable because it doen't have a real lot of cores.
Often this is due to having a lot of apps running. Have a look in Task Manager and see if you can definitely disable and/or uninstall any you definitely don't need.
You could also have a problem if your CPU is overheating.
