Edit: Problem fixed, it was a faulty/broken 24pin cable, never seen that to be wrong...
Fresh new build, I'm not certainly new to building.
Specs:
MSI PRO Z790-A WIFI
i7-13700KF
Kingston Fury 32GB 6000MHz kit ( KF560C36BBEK2 - 32 )
MSi Ventus 3x 4070
AORUS modular psu AP750GM
2TB M.2 from Kingston
Assembled carefully everything in place, initially after power button is pressed cpu red light comes on for like a split of a second, then goes to yellow dram light and stays hanging on there.
What I've tried: (btw, everything assembled on the cardboard of the mobo)
Removing gpu, m.2, using only one ram stick in every single slot, even tried with no ram sticks and that part went right, since it is supposed to stay on DRAM if there is no RAM installed
Also tried leaving it for some "DDR5 training" and I've heard that it can take up to 15 mins for it to train. Didn't help + cpu cooler got REALLY hot like I mean REALLY hot, it's mounted properly btw.
Running out of ideas and also out of my mind.
Thanks for any comment!
Specs:
MSI PRO Z790-A WIFI
i7-13700KF
MSi Ventus 3x 4070
