Hey all,
Thankfully I haven't had to make this post in a while, but of course I run into tech problems just weeks before I'm set to move out for college. My brother was not comfortable using my old P400S without the solid side panel (which was misplaced) to cover all the cables, so he wanted a case that was fully enclosed. I took this as an opportunity for me to buy a Meshify C and move his stuff to my S340. We moved both systems in the same room, and I treated the hardware with great amounts of caution. However, for some reason, his PSU was being very difficult to remove from the P400S, so I ended up having to remove the fan grill to get it out. Unfortunately, with the PSU I have, that voided the warranty. After building my system in the Meshify C, it booted up without a hitch. However, when it was time to test my brother's system, we did not have as much luck. The system does not power on at all. My initial thought was that the jumpers were placed incorrectly, so I tried shorting out the appropriate pins with a screwdriver: no luck. To test the PSU, I got one of my dinky old H110 boards that still had a pentium in it. The heatsink started spinning, and the HDD's started. However, after testing it a few more times, the system would only stay powered on for 10 seconds or so (maybe due to it not having any RAM?) before it suddenly shut off. What confuses me is that, when hooked up to his board, the onboard LED flickers for a second when I switch on the PSU, but I'm unable to get anything out of the system regardless.
My suspicions are this: something damaged his PSU while the fan grill was off, but I don't know how likely that is. If you have any ideas, PLEASE help. His specs are as follows:
Ryzen 7 2700X
Asus Prime X470 Pro
16GB DDR4 RAM
GTX 980 Ti
Enermax Platimax 600W 80+ Platinum PSU
Ryzen 7 2700X
Asus Prime X470 Pro
16GB DDR4 RAM
GTX 980 Ti
