Question System powers on GPU, Storage, and fans but motherboard won't and cpu fan will not spin
Notthegut
Evening fine people
Recently moved my pc from a diffrent room to a new room and tried to turn the system on, however when I tried to the pc will power on the GPU, the storage drives and a seperate fan controller but the motherboard will not power on as can be seen by the fact it's LED will not power up and the cpu fan doesn't spin. I tried plugging the computer back into the original place but the problem remains the same. The PU is receiving power as is the fan controller but my motherboard will not
Further to this, after moving the setup iv noticed a strange crackling noise coming from the PSU. This hasn't happened before and I was wondering could this be a Psu issue despite the fact it can power on both the GPU and the case fans. I unplugged and reset both the memory sticks in case this was the issue and tried to remove individual parts starting with the GPU to see if this remediates the issue but to no resolve
As always any assistance is greatly appreciated and system specs are down below, Thank you ever so much you amazing people
RTX 3060 - GIGABYTE
15 8600k - INTEL
600 W PSU SILVER - EVGA
Z370 PD3 MOBO - GIGABYTE
2400mhz 8gb × 2 DDR4 RAM - CORSAIR
Evening fine people
RTX 3060 - GIGABYTE
15 8600k - INTEL
The fact that the problem occurred after a move, I'd suspect a bad connection somewhere that got created during the move. Reseat cable connections one at a time, retrying after you make each change. Like wise, try reseating any boards, one at a time.
Latest posts
