Question System randomly restarts ?
Nov 26, 2021
14
My system randomly restarts, playing games or even idle. Even sometimes when it restarts it restarts multiple times before home login screen ?
Specs of pc are:
I5 2500k not overclocked
Gtx 770
P8h61-mx r 2.0
G skill 2400 cl10-12-12-31 2x4gb
Corsair cx550f restarts
Adata su650 SSD
Thanks in advance
Nov 10, 2021
9
Specs of pc are:
Gtx 770
P8h61-mx r 2.0
Adata su650 SSD
Thanks in advance
Very stupid idea but it happened to me
Did you clean your CPU fan and made sure you locked it back up ? I accidentally forgot one time and the pc randomly restarted.
Or did you do anything with the Hardware at all ?
Nov 26, 2021
14
I haven't touched the hardware at all, the cpu fan is brand new so no dust and it connected all correctly
Nov 26, 2021
14
CPU CORE 0.976 V
MEMORY CONTROLLER 1.008 V
AVCC 3.328 V
3VCC 3.328 V
VIN4 1.016 V
VIN6 1.080 V
VIN7 0.144 V
VIN8 0.984 V
VIN9 0.112 V
VIN10 1.016 V
VIN11 1.008 V
VIN12 1.080 V
VIN13 0.112 V
VIN14 0.120 V
VIN15 1.664 V
these are my voltages of psu are they all ok?
Nov 26, 2021
14
I'd start by running a memtest, or remove a stick of RAM, if it still happens try the other stick.
MemTest64 - Memory Stability Tester (techpowerup.com)
Module 0:
DDR3, 4096 MB, 64-bit, 1333 MHz
ChannelA-DIMM0 BANK 0 04CD F3-2400C10-4GTX
Module 1:
ChannelB-DIMM0 BANK 2 04CD F3-2400C10-4GTX
0.000: Detecting usable memory (8136 MB theoretical max)...
3.141: Test finished with no errors detected
11.391: 6784 MB Test starting on 4 CPUs...
11.407: Allocating memory...
15.579: Memory locking failed (might be reserved by other apps/kernel)
17.532: Test finished with no errors detected
this was after the mem test
