system resources
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hello.
Where can I read the % of the system resources I'm using?
(WinXPSP2, Dell 9200)
Thanks.
Steffo
Hi, Steffo.
The term "system resources" as used in Win9x/ME has no meaning in WinXP. As
the other poster said, the Task Manager will tell you all you need to know
(most of the time), and clicking View will let you choose the information
that you want to see. But, you will notice, "system resources" is not one
of the choices offered. Perhaps the closest to what you are asking about is
the "CPU" column on the Processes tab. You might find that the System Idle
Process is using 98% or more of your CPU, which just means that 98% of the
time your computer is idling (like your car at a stop light), waiting on you
to give it something useful to do.
It takes a while after moving to WinXP to lose the Win9x/ME mindset. ;^}
But, even though they look a lot alike on the surface, WinXP is quite
different from Win9x/ME under the skin.
RC
R. C. White, CPA
San Marcos, TX
rc@corridor.net
Microsoft Windows MVP
"Steffo" <steffo@nospam.com> wrote in message
news:41e28cea$1_3@news.bluewin.ch...
> Hello.
> Thanks.
> Steffo
For CPU, memory, pagefile and networking: Press CTRL-Shift-ESC, or right
click your task bar and select "Task Manager". For disk usage: Right click
the respective partition and select "Properties", or run Disk Management
(Control Panel -> Administrative Tools -> Computer Management -> Disk
Management). For other resources, go to Control Panel -> Administrative
Tools -> Performance.
> right click your task bar and select "Task Manager". For disk usage:
> Right click the respective partition and select "Properties", or run
> Disk Management (Control Panel -> Administrative Tools -> Computer
> Management -> Disk Management). For other resources, go to Control
> Panel -> Administrative Tools -> Performance.
Thank you for that, Andre'.
Is the CPU usage and the system resources the same thing?
No. WinXP does not have the System Resources problem Win 98 had. System
Resources referred to two 64 KB heaps in Win98. These do not exist in WinXP
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup only. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com./athome/security/protect/default.aspx
news:41e2941b$1_3@news.bluewin.ch...
Thanks for the explaination, Mr White.
I'm actually looking for the % of the system resources I'm using (as in
WinME, as you guessed) in order to know if I can run another program or if I
better close one before opening a new one.
Is the reading of the % of CPU used the same thing?
And if not, where can I get the info I need?
Thanks again.
Steffo
R. C. White wrote:
> Hi, Steffo.
> WinXP. As the other poster said, the Task Manager will tell you all
> you need to know (most of the time), and clicking View will let you
> choose the information that you want to see. But, you will notice,
> "system resources" is not one of the choices offered. Perhaps the
> closest to what you are asking about is the "CPU" column on the
> Processes tab. You might find that the System Idle Process is using
> 98% or more of your CPU, which just means that 98% of the time your
> computer is idling (like your car at a stop light), waiting on you to
> quite different from Win9x/ME under the skin.
> RC
>> Hello.
>> Thanks.
>> Steffo
The System Resources you are looking for do not exist in WinXP. You can
open another program.
Protect your PC
news:41e29565_2@news.bluewin.ch...
> I better close one before opening a new one.
> Thanks again.
> Steffo
> R. C. White wrote:
>> Hi, Steffo.
>> RC
>>> Hello.
>>> Thanks.
>>> Steffo
Does XP have "Resource Monitor"?
It used to be a utility in Windows 9x up to Windows 2000....probably buried
somewhere in XP - but it may not install by default so you need to go to control
panel, Install Programs.
Otherwise I'm sure there's plenty of progs on the Internet that can help. Or
does the Task Monitor (ctrl-alt-del in Windows NT/2000/XP show things like system
resources??
> Hello.
> Thanks.
> Steffo
In news:eApBg$79EHA.3592@TK2MSFTNGP09.phx.gbl,
Andrew Murray <admurray@iinet.net.au> typed:
> 2000....probably
> buried somewhere in XP - but it may not install by default so
> you
> need to go to control panel, Install Programs.
> can
> help. Or does the Task Monitor (ctrl-alt-del in Windows
> NT/2000/XP
> show things like system resources??
No, it doesn't show System Resources because System Resources
don't exist in Windows XP.
The term "System Resources," in Windows 9x and Me, referred to a
particular data structure that doesn't exist in Windows XP.
That's one of XP's many improvements over 9X. There are no System
Resources to run out of or to be concerned with.
Ken Blake - Microsoft MVP Windows: Shell/User
Please reply to the newsgroup
> can open another program.
Following up to what you said, I'm wondering if there is a setting I can
change in order to avoid freezing with CPU 100%.
I thought that the system is supposed to use some gard disc space when RAM's
full: how can I improve this feature?
Just to give you an example: my OE6 is open, an XP browser page's open, the
messenger's open, my FX trading site is open.
With all that, I'm using 95% CPU and my PC freezes if I want to open a
graphic page (like a diagram chart) within the trading site.
It's exactly the same of when I was using WinME, 1G processor, 256M RAM and
I wanted to improve buying WinXP, 2G processor, 1G RAM.
But nothing's changed: is there anything I can do to enhance the memory
space?
Thanks for your help.
Hi, Steffo.
Something may be wrong in your computer! :>(
That should be PLENTY of RAM to run most anything short of a
graphics-intensive application, such as editing video.
Yes, many things HAVE changed! As we have been telling you, WinXP is
designed quite differently from WinME. The term System Resources no longer
exists as it did in WinME.
> is there anything I can do to enhance the memory space?
What are your settings for Virtual Memory (also known as Paging File or Page
File or Swap File)? You might want to read MVP Alex Nichol's explanation of
the subject first:
Virtual Memory in Windows XP
http://aumha.org/win5/a/xpvm.php
Then go to System Properties | Advanced | Performance/Settings | Advanced.
What does it say at the bottom of this window? "Total paging file size for
all drives" should be about 1.5 * your RAM; on my computer with 1 GB RAM,
this number is 1535 MB. Click Change. On this screen, the "Recommended"
and "Currently allocated" numbers at the bottom of the screen should both be
about the same as that 1535 MB. This screen is where you decide where your
page file should be created and how big it should be. You haven't told us
how many HDs you have or how they are partitioned, so we can't recommend
anything other than the "generic": First, select each Drive, in turn, and
select No paging file, then Set for that drive. Then go back to the one
Drive where you want the page file to be created, click System managed size
for that drive and click Set for it. Then OK your way out; you may have to
reboot for your change to take effect.
Now, you should have plenty of physical and virtual memory to handle ANY
application. To keep an eye on it, bring up the Task Manager. The
Performance tab will show you, both graphically and in table form, how much
memory you have and how much has been used and is being used. Among other
items, under Commit Charge, you should see "Limit 2518692" (in KB - that's
about 2.5 GB, which is your 1 GB physical memory plus 1.5 GB page file); the
Peak number is the most of this memory that you have used in your current
session.
Task Manager's Processes tab shows how your CPU is being used by the various
running processes. The CPU column should always add up to 100%. If you
click on this column head, the table will be sorted by CPU usage; click
again to reverse it from least-used to most-used. Most of the time, the top
item will be System Idle Process; it quite often shows 99%, or close to it.
This means that most of the time, your CPU is just sitting there idling,
like your car engine at a stop light, waiting for you to give it something
useful to do.
If your CPU is actually busy 95% of the time on something other than the
System Idle Process, please tell us which process is using that CPU time.
There are a few situations in WinXP that can result in the System process
using 95%, and we can help you cure that if it really is happening to you.
More often, though, excessive CPU usage is caused by some malware in your
computer.
> the messenger's open, my FX trading site is open.
My OE6 is open now, including this Compose window, plus a browser page, and
Task Manager itself; Messenger is open enough to show its icon, but I don't
use it. System Idle Process is using 95%-99% (it normally fluctuates
dynamically). I'm not sure what you mean by an FX trading site; is this a
web page open in IE? How much CPU usage does it show?
Some viruses or other malware can also cause excessive CPU usage. Have you
been practicing "save hex"? Have you run a virus scan? Recently?
RC
R. C. White, CPA
San Marcos, TX
rc@corridor.net
news:41e66346$1_3@news.bluewin.ch...
> RAM's full: how can I improve this feature?
> and I wanted to improve buying WinXP, 2G processor, 1G RAM.
> space?
> can change in order to avoid freezing with CPU 100%.
> when RAM's full: how can I improve this feature?
> open, the messenger's open, my FX trading site is open.
> RAM and I wanted to improve buying WinXP, 2G processor, 1G RAM.
> memory space?
First eliminate any spyware.
What You Should Know About Spyware
http://www.microsoft.com/athome/security/spyware/devioussoftware.mspx
CAUTION!!!!! Before you try to remove spyware using any of these programs ,
download a copy of LSPFIX from any of the following sites:
http://www.cexx.org/lspfix.htm
http://www.spychecker.com/program/winsockxpfix.html
(if your OS is Win2k or XP) The process of removing certain malware may kill
your internet connection. If this should occur, this program, LSPFIX, will
enable you to regain your connection.
See
Dealing with Unwanted Malware, Parasites, Toolbars and Search Engines
http://mvps.org/winhelp2002/unwanted.htm
Note that AdAware and SpyBot S & D will each catch some things the other
won't. Also, each needs to be updated with the program's update function
before every use, even when just downloaded. There's also a lot more to do
than just those two programs. CWShredder is also available here:
http://www.intermute.com/products/cwshredder
**Post your HijackThis log to
http://www.spywareinfo.com/forums/
http://forums.tomcoyote.org/
http://castlecops.com/forum67.html
http://www.wilderssecurity.com/ or the Spyware forum at
http://forum.aumha.org/viewforum.php?f=30 for expert analysis, not here.**
Alternative download pages for Ad-Aware, Spybot, HijackThis and CWShredder
may be found on this page:
http://aumha.org/a/parasite.htm.
See also:
http://www.microsoft.com/downloads/details.aspx?FamilyID=321cd7a2-6a57-4c57-a8bd-dbf62eda9671&DisplayLang=en
for the new Microsoft program which was previously released by Giant
Software.
See this link for information about malware:
http://arstechnica.com/articles/paedia/malware.ars
If nothing there helps, please post back to this thread.
Protect your PC
> I thought that the system is supposed to use some hard disc space
> memory space?
Hi RC.
Fx trading is a stand-alone site where you trade currencies: in each page of
the program (connected to the bank server), you can set up several windows
(i.e.: grafic charts, sell/buy applications, market news and updates,
banking experts chat windows.....) and it's constantly on line to retrieve
value changes of all currencies (24hrs/day, 7days/week) = CPU usage is
between 10 and 40% (memory usage 83488K).
My laptop (the one with 2G proc and 1G RAM) is brand new and I installed all
updates, run AV and AdAware.
I've checked the Page File value and it is set from initial size1500 to
maximum size 3000MB.
Should I delete those value and replace it with the option "system managed
size"?
Someone else told me those values should be from 150 to 3300MB: what do you
think about it?
What do you recomand?
Cheers, Steffo
R. C. White wrote:
> Hi, Steffo.
> longer exists as it did in WinME.
> or Page File or Swap File)? You might want to read MVP Alex Nichol's
> explanation of the subject first:
> Advanced. What does it say at the bottom of this window? "Total
> paging file size for all drives" should be about 1.5 * your RAM; on
> my computer with 1 GB RAM, this number is 1535 MB. Click Change. On
> this screen, the "Recommended" and "Currently allocated" numbers at
> the bottom of the screen should both be about the same as that 1535
> MB. This screen is where you decide where your page file should be
> created and how big it should be. You haven't told us how many HDs
> you have or how they are partitioned, so we can't recommend anything
> one Drive where you want the page file to be created, click System
> managed size for that drive and click Set for it. Then OK your way
> out; you may have to reboot for your change to take effect.
> ANY application. To keep an eye on it, bring up the Task Manager. The
> form, how much memory you have and how much has been used and is
> being used. Among other items, under Commit Charge, you should see
> "Limit 2518692" (in KB - that's about 2.5 GB, which is your 1 GB
> physical memory plus 1.5 GB page file); the Peak number is the most
> of this memory that you have used in your current session.
> various running processes. The CPU column should always add up to
> 100%. If you click on this column head, the table will be sorted by
> CPU usage; click again to reverse it from least-used to most-used. Most of
> the time, the top item will be System Idle Process; it quite
> often shows 99%, or close to it. This means that most of the time,
> your CPU is just sitting there idling, like your car engine at a stop
> light, waiting for you to give it something useful to do.
> the System Idle Process, please tell us which process is using that
> CPU time. There are a few situations in WinXP that can result in the
> System process using 95%, and we can help you cure that if it really
> is happening to you. More often, though, excessive CPU usage is
> caused by some malware in your computer.
> page, and Task Manager itself; Messenger is open enough to show its
> icon, but I don't use it. System Idle Process is using 95%-99% (it
> normally fluctuates dynamically). I'm not sure what you mean by an
> FX trading site; is this a web page open in IE? How much CPU usage
> does it show?
> RC
>> a graphic page (like a diagram chart) within the trading site.
>> memory space?
Hi, Steffo.
Thanks for the explanation of Fx trading. I'm not sure what impact it would
have on memory or CPU time or virtual memory. The 83488 KB memory usage is
only 83 MB, which is almost negligible in a computer with 1 GB RAM + virtual
memory. CPU usage of up to 40% seems high, but many programs can spike that
high momentarily. You might check with the program vendor to see if anybody
else is reporting problems in using it with WinXP.
Do any other processes show over 10% CPU usage in Task Manager?
> size"?
That's what I would do. If it doesn't work for you, then you can back up
and use the old values.
> you think about it?
I'm no expert in these areas, just an experienced user - and I haven't
experienced the problems you are having. Have you read the article I gave
you the link for? That's the only recommendation I have.
Please report back when you track down the problem - and the solution.
RC
R. C. White, CPA
San Marcos, TX
rc@corridor.net
news:41e69e23$1_3@news.bluewin.ch...
> Hi RC.
> of the program (connected to the bank server), you can set up several
> windows (i.e.: grafic charts, sell/buy applications, market news and
> updates, banking experts chat windows.....) and it's constantly on line to
> retrieve value changes of all currencies (24hrs/day, 7days/week) = CPU
> usage is between 10 and 40% (memory usage 83488K).
> all updates, run AV and AdAware.
> size"?
> you think about it?
> Cheers, Steffo
> R. C. White wrote:
>> Hi, Steffo.
>> of the time, the top item will be System Idle Process; it quite
>> does it show?
>> you been practicing "save hex"? Have you run a virus scan? Recently?
>> RC
>>> memory space?
Frank, there's no spyware in my system.
Do you know the values I should write in the paging file size?
Or should I leave it on "system managed size?
>> memory space?
news:41e6cceb$1_3@news.bluewin.ch
Let Windows manage it.
If you only ran one anti-spyware program you do NOT know that you're free of
spyware. Which did you run.
Protect your PC
