CPU: Ryzen 7 3700X w/ stock cooler (Wraith Prism)
RAM: 32GB (2x16GB) G.Skill (F4-3200C16-16GVK)
SSD: Intel 660p M.2 2280 2TB
GPU: MSI Ventus OC 2070 Super
MB: ASRock B450M/ac
Case: NZXT H510 ATX Mid-Tower
Fans: 4 x Cougar Vortex 120mm (CF-V12HB)
- 2 x Front (Intake)
- 1 x Rear (Exhaust)
- 1 x Top (Exhaust)
Typical issue: Playing WoW on #3 graphics setting and my card is still hitting 70C. I'm getting the warm (not quite burning) plastic smell. None of the temps in the system seem damaging, and I have overtemp protection enabled in my bios.
The Cougars run at 1200rpm/60.4CFM. I've used AsRock A-Tune to adjust their profile to hit max RPM at 60C.
The Wraith Prism blows against the side of the case, which I'm sure is not helping circulation. I've considered getting a "front-to-back" cooler a la Hyper 212 EVO-sytle to combat this. Otherwise I'm not so much worried about the CPU temps themselves. Maybe use a 120mm rad for the CPU?
The MB only has two fan headers aside from the CPU pins. So front and back fans are connected with splitter cables, respectively.
That's about all I can think of...
Any thoughts would be appreciated.
Thanks!
MB: ASRock B450M/ac
- 1 x Top (Exhaust)
Thanks!
