I started having this issue where my computer would shut down during csgo competitive play. Never did it during any other gameplay in csgo, ONLY comp. I can run GTAV for hours on end without issue, so i figured it wasnt a power or temp issue. When playing my core temps are around 70-73. Its still a little hot, but not too bad. Ive been told a few times that csgo puts a decent amount of stress on the CPU.
I know most people say that your CPU should idle around 35. Noticing mine was around 55 I decided to clean and replace the thermal paste. I booted up and immediately loaded up hardware monitor. This was the result.
https://postimg.org/image/qy320so63/
After being off for hours, I boot up and within 2 minutes the cpu is in the mid to high 50s. But ok, maybe its hardware monitor. So I tried MSI afterburner, and coretemp. All 3 show the same temps.
The case seems pretty cool, all the fans are working and despite using a stock heatsink, I havent had an issue with temps. I honestly havent monitored temps in quite some time, as I dont overclock and never really needed to. But I seem to recall the cpu always being a bit higher idling than normal, but not this much.
Wondering what I should do here. The heat sink is tightly secured and I know the paste is fine.
