Question System Upgrade
Dec 12, 2019
6
Hi guys I'm new here, I have a current system which is 7yr+ old
Intel core i5-3470
MSI h77 mobo
8gb ddr3 ram
120gb kingston ssd
560w Seasonic Gold Psu
my question is, is it worth it to upgrade unto a Ryzen 3 2200g system with a 16gb RAM?
or all I need is a GPU for my old system to play the recent games?
thanks
"Worth it" is subjective. The 2200G is a stronger CPU by most metrics, but a 3470 is still pretty viable. I wouldn't recommend running out and buying a 3470 in 2019/2020, but if you already have it, it should still net a solid experience.
A 3470 will still pair well enough with something like an RX570 or RX580, and allow you to play modern titles on reasonable settings.
Reactions: rustincohle7
The coast for a 2200g, motherboard, and ram, you could get a good GPU, that will greatly increase your gaming performance. As games have become more multithreaded, a drop in upgrade of a 3rd gen i7, or Xeon E3 1230v2, or better, might not be a horrible idea either. Depends on what exact model you have.
thanks guys, will my system hold up since it's a 7yr+ old plus? If I add a RX 570 or 1650 specifically my PSU, it will not explode or anything right?hehehe althought it is working just fine right now, my last GPU was like 6 years ago, a GTX 770 then I sold it, been using the onboard gpu ever since..
Well in terms of gaming performance the system will perform much better with your current setup + GTX 1650S then it would with the 2200G(iGPU). The 1650S (Super) performs close to the RX 580 and has a power power draw so there shouldn't be a issue using your current PSU. Then when it's needed, upgrade the CPU/MB/RAM.
Intel core i5-3470
MSI h77 mobo
8gb ddr3 ram
120gb kingston ssd
thanks
Compared to your i5-3470 and if you had say an RX 570 or GTX 1650 Super, a Ryzen 2200g with DDR4 3000-3200Mhz ram would get you maybe another 10- 20fps depending on the game. You would be better off getting a Ryzen 5 2600 for $110-120 vs about $100-105 for a 2200g or save for a 3600 and get it for around $150 in about 5-6 months. If the games you play are not too CPU demanding, you could just throw a graphics card in and buy a new system later on when you need it.
thanks bro, but I have doubts about my PSU since it is a 7yr+ old, and I read that PSU has just a lifespan around that age and the capacitors will start to wear down under heavy load..
I believe there is some degradation on the caps over time but its not something I know well so maybe someone else can chime in on this.
If the PSU is out of warranty then get a new one, the Seasonic Focus Gold Plus 550W is a great unit and comes with a 10 year warranty.
Yeah so not really sure if I want to put a GTX 1650 Super to my old system, I was thinking of building a new rig instead.. how about this
Ryzen 3 2200g
gigabyte ga-a320m-s2h v2
16gb 8gbx2 T-force Vulcan Ram
240ssd
EVGA 450w bronze PSU
Gigabyte GTX 1650 Super
is that good enough?
Intel core i5-3470
MSI h77 mobo
8gb ddr3 ram
120gb kingston ssd
thanks
im selling my 2200g with box u want ?
Ryzen 3 2200g
240ssd
What is your budget? If you can extend your budget some, you really want to avoid the a320 platform and get a B450 motherboard and a 550watt PSU with 2 PCIE cables. Again, it makes no sense to get the 4 core 4 thread 2200g with it only being around 12fps faster in most games than your 4 core 4 thread i5-3470. It's a side grade and it would make more sense to just buy a new power supply, graphics card and possibly 8GB more ram for your current system.
My last suggestion is to just save up for for a Ryzen 5 3600 and B550 motherboard to buy them in 6-8 months when the CPU has dropped in price. It will be worth it in the long run compared to a 2200g which you would likely need to replace in a year.
okay man, that makes more sense, thanks for that advice I really appreciate it.. I may just have to buy a PSU and a GTX 1650 Super, and clean my rig out, hasn't been clean for like 3 or 4 years lol because I got ashtma.. My Proc and Mobo are still good right? no worries about capacitors like the PSU?
Although your PSU is 7 years old, it's probably still good for another 2 years minimum since it's a gold rated Seasonic (good brand) and has higher quality components inside than most PSUs. I've been running a Corsair TX750 orange label I got back in 2009 in another system that I had running 24/7 for around 6 months mining cryptocoins with GPUs and it's still working fine. It's not on 24/7 anymore, but doesn't have any issues supplying power to an i7-2600k oc'ed I've been using for video encoding.
The GTX 1650 Super you are planning to get uses less power than the cards your PSU would have been powering 5-7 years ago so it's even less of a strain on it than say a GTX 970 from 2014 which uses 2x6pin PCIE and around 50-60% more power for the same performance compared to the GTX 1650 Super.
Edit - BTW, that TX750 I mentioned was not that great of a PSU, it was just a cheap replacement to a dead 600watt.
