Upgrade question
Hi everyone, my current setup is this:
-I5 6600k cpu air cooled
-Gigabyte gtx 970 g1 gaming
-Asus 170 pro gaming motherboard
-Corsair 750w power supply
-2x8 Gb 3200 or 3600 mhz ram
-A random and old 250gb ssd
-Western Digital Green 2TB hard disk
I’ve built this pc in 2016-2017 and it still runs good in full hd (some games on ultra some one high, but I can feel it struggling) I was thinking to upgrade some parts because I would like to play full hd but all on ultra without problems.
I have a budget of 500-600 euros but if I can spend less I would love that.
I was thinking about:
-buying another ram module like the one I have so I would have 4x8 modules
-replacing the ssd with a Samsung 980 that I would use only for the os
-replacing the hard disk with a better one, maybe a WD black I don’t really know
-replacing the 970 with a 4060
My questions are:
-Is the 4060 a good card or I can get a better value
-Is the ram worth upgrading? (About 50€)
-I should keep using the ssd only for the os and the hard disk for games, or I could buy a 2TB ssd to use for everything?
-Is my cpu going to be a bottleneck? (It’s overclocked a little)
-This pc is worth upgrading or should I buy a new one?
Thank you very much for the responses and if you have some suggestions I’m very happy to listen
My questions are:
