Hello to all
I have a home-built system that has worked reasonably well for some years. Ie, I have had to replace components from time to time, but it is generally a workhorse. ASRock p4v88 MoBo, Pentium 3 processor.
The other day I rebooted and -- I could not get the system to come back on.
I have tested the PSU. 5 and 12 volt circuits check normal (within 5%) of nominal settings with MoBo plugged into system. 3.3 tests low, 2.7-2.9 volts.
The CPU makes faint ticking sounds, but does not heat.
No acoustic signals from the MoBo.
Fans are both on, but no spin-up on HDDs or DVD drive.
I have reseated all cards, and tried to get POST with all cards and HDDs removed (only CPU and RAM in system). No dice.
The RAM, incidently, has been in the system for at least a year.
I'd appreciate any help.
-Myke
-Myke
