Archived from groups: rec.games.pinball (
More info?)
Glad you figured it out. Sometime have a cup of coffee ( or your favorite
beverage ) and look over the switch matrix in your games manual. They are
all connected together. A broken wire can take out the next switch, a stuck
closed switch can short the matrix and make others erratic. A backwards
diode can trigger other switches. The switch matrix is an amazing thing,
simple, yet the littlest thing can cause you headaches.
Good job on sorting it out. And you learned something very important. When
things act up - what is the last thing you did ? That can save you a lot of
time. LTG
"Max" <doug@pattoncentral.com> wrote in message
news:1125972216.837017.244120@f14g2000cwb.googlegroups.com...
> OK Lloyd, earlier the switches were showing up in the matrix and after
> swaping out boards they didn't. I forgot that extra board has problems.
> BUT the good news is I figured it out. The switches were # 57-58. I
> noticed that #55 was shomehow connected and closed when it should be
> open. #55 was a switch way up under the bolder garden and the new
> rubber stuck it in the closed position. I have no idea how that effects
> the slingshots but as soon as I open the contact up i reached down the
> touched the slingshot and it fired. After messing around with #55 all
> is working fine. THANKS A MILLION FOR YOUR HELP! Any idea why it works
> that way?
