Archived from groups: rec.games.video.arcade.collecting (More info?)
Hi I have a Star Castle made by Hoei the monitor is different than the
Cinematronics one. The problem I have is the brightness is low, you can turn
it up but it goes out of focus and can't be adjusted. Also in order to have
the screen bright enough to view everything you can see the points where the
vectors join together like a spiders web. I have tried all the adjustments
on the monitor but no luck. Is this likely to be a bad tube or Just a Cap
change? Any info would be a great help. Thanks
