G
Guest
Guest
Archived from groups: rec.games.video.arcade,rec.games.video.arcade.collecting,rec.games.video.arcade.marketplace (More info?)
I got this machine at auction and it had several issues
1) No Music - First I thought it was DBS2 MPEG sound board then found out
simply connector plugged in upside down. Easy fix once I found it.
2) No sound to rear speakers - Thought is was amp because when I switched
CN8 and CN9 the rear sound came out the front speakers so main game board is
definitly putting out sound for rear channel. Put them back and got front
sount back out of front speakers.
Thought reach channels on amp were gone so purchased new AMP and exchanged
but same issue.
Anyone have any idea what the proper jumper settings are on amp?
There are two headers with about 2 rows of 10 parralle pins on each.
Each header has a jumper in a location. Game came this way. Replacemnt amp
I purchased had no jumpers so I just transfered them to identical settings.
Still no go. Same issue.
Any other ideas?
Also, how in the world do you disconnect drivers seat from slides? Do you
need to remove one of the slides?
I want to ohm out paths to make sure not something simple like broken wire
but my guess is that it is not that simple because neither speakers have
sound.
Segas online manual do say anything about either the jumpers or removing the
drivers seat.
Any help greatly appreciated.
Regards
Bob Presutti
but same issue.
Any other ideas?
sound.
drivers seat.
Regards
Bob Presutti
