G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Good morning to all!
Posted a question about flippers a couple days ago. The right side
flipper of our High Speed is weaker than the left one. So I thought it might
be weak voltage.
Ray Johnson replied with a very nice post about what to check. I did
notice that the same voltage is measured on both sides of the right side
flipper (cab) switch.
The left side only has voltage on one side. I am thinking it may be a
shorted cap that is mounted on the flipper switch so I have ordered several
replacements as there are 2 on the right side (extra switch for upper
flipper).
Any other thoughts???
I am thinking about making a jumper wire from the flipper volt board to
the flipper to see if that makes a difference, but I thought I would replace
the caps first! Although I don't think that's the problem!
MD
be weak voltage.
flipper).
MD
