G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
OK, I wanted to keep this short but provide enough details, so please bear
with me. First, all boards (MPU, SDU, Power Supply) have been rebuilt and
ground mods done. Voltages on all test points are accurate as per Marvin's
site. Sound board is not hooked on, but the speech board works. Problem:
I'm blowing fuse F3 on the power supply board that supplies the +5V logic to
the MPU when the left upper solenoid switch is activated. The easiest way
to isolate and cause the problem:
1. All connectors are hooked up to the power supply and MPU
2. Disconnect J2 from the SDU to prevent power going to the solenoids
3. Disconnect J4 from the SDU to prevent solenoid logic from getting into
the SDU
4. Starting it up, works fine. Switches cause no errors
5. Now, shutdown and plug in J4 to start the solenoid bank logic going to
the SDU
6. Everything works again, but as SOON as I trip the switch for the left top
kicker, F3 on the power supply blows and I lose the +5V
This is one of the continuous solenoids. I have replaced all major parts in
this line on the SDU board (U2, U4, TIP102, 1N4004) - same results. The
resistors all test out as expected, and the ceramic cap by the TIP102 tests
good as well, so there aren't any other parts I can see to replace.
The diode and capacitor on the switch itself have been replaced as well. I
also swapped U10 and U11 on the MPU in case one of them was bad - same
results. When I previously had all the solenoids hooked up, the playfield
fuse would eventually blow as well and the solenoid would be locked on
(unplugging the pin obviously prevented the lock).
Any ideas on what to check next? Could it be something on the MPU causing
this surge? Something on the power supply? Under the playfield? Any ideas
anyone has would be most welcome at this point - I'm fresh out. Thanks.
- Sean
the SDU
the SDU
- Sean
