Hi,
I have a question for all you more intelligent people out there about what is happening in my computer when I experience an fps spike. I have recently run out of explanations for why I may be experiencing fps issues when my hardware is not being fully utilized. For instance I may experience fps drops when my gpu is at 55-60 'C or when my CPU is less than 70' C, but those are well below the temperatures at which my hardware ought to throttle itself to avoid damage. What is technically the justification for an fps drop when the hardware is being under utilized? I'm trying to understand what is happening on a deeper level between say a games interface and a gpu/cpu being unable to render an image at a faster pace.
The common example I experience is say something like playing a game at 75-80 fps, experiencing an fps drop, but never falling below 45-50, while somehow managing to be very hard on the eyes. It is as if my computer is dropping 15-30 fps all in the span of 0.3 - 0.4 seconds, so that effectively my computer has 0 frames being rendered for some portion in a given second in time. At a glance it looks normal when I see the fps reads 50, but my intuition tells me that the 50 frames occurred as normal in the first half second, and the second half of the second produced some horribly low number, perhaps only 10 frames. I might be fudging the numbers in this example, but is this possible? How can I avoid an fps spike when my hardware is being under utilized? I'm at a loss more or less and random googling doesn't seem to help me much at all. I ordered more thermal paste after examining my cpu, but the paste on previously was still okay (last replaced around 3-4 years ago, but looked okay otherwise), and the temperatures were never near the range at which my cpu throttles itself.
Would someone more intelligent than me mind explaining this to me or perhaps point me in the right direction? Like I said I'm kind of at a loss right now.
My specs are:
i7 4790k 4.0 ghz
geforce gtx 1660 super
16 gigs of ram
and the O.S. is on an SSD
I use MSI afterburner and Core Temps to monitors my temperatures also.
I look forward to any replies. thanks guys ! 😀
My specs are:
i7 4790k 4.0 ghz
16 gigs of ram
