Are all of these GPUs out of warranty?
So, he's my question. If Nvidia says this is user error, do they deny warranty claims based on it being user error and not a defect?
Now moving on to this topic/thread on a general level rather than you the specific post I replied to...
There were problems that didn't happen with older connectors. Then they also said you can't bend the cabling too much near the connector, to the point that, if I recall correctly, it was mentioned that you might want to check if your case has enough extra side clearance to accommodate this connector's needs.
Then there was a revision they actually seems to address the problems.
Yet, it seems like there are people dedicated to perpetuating the belief that it's entirely user error. Or, in what appears (to me) to be an attempt at false equivalence, mentions of why it can't be both a design flaw AND user error.
Why this dedication to blaming the user?
And even some going so far as to say that because it's a new design for a high end, expensive product, some issues should be expected. To which I'd say that might be expected, a little, for a budget product where corners were cut, but most certainly NOT for a halo product.
EDIT: fix mobile fumble-fingered typos
