I have a few issues and I hope I'm in the right sub forum I recently put together a new system:
EVGA 780I P04
Q9450 D-tek fuzion cpu block (stock nozzle)
Microres 1/2 tygon MCP-655b pump
got everything running bumped the FSB up to 400 and got and easy 3.2ghz
with out touching any other setting in the bios. now here's the problem
The temp readings vary ALOT from core to core (see pic)
although both programs show different temps you can see that cores 1 and 2 are over 10c-15c higher than cores 0 and 3.
On my D-tek fuzion I have it tightened down till the springs are almost completly compressed and applied a thin layer of as5 on both sides.
Does the quad nozzle fix this problem or should I just reapply TIM and reseat my block? I have the nozzle kit, but dont really want to tear it all down unless I really have to. 🙁
EVGA 780I P04
