Temperature problem with Cpu
bigal80ak
119
4
I currently have a computer that never had problems until a bit ago when i got a new program and it runs at 100% usage for about 2.5-3 hours. I then noticed it is idling at 43 celsius and max out at 70ish. I know this is very hot cannot figuring out why its getting that hot i mean i know its running really hard so i expect it but whats the week point. Also fan speed is set to high would disabling cool n quiet in bios help? or adjusting thermal cycling? or is it hardware here is the machine. I have another pc in same room and more powerful stock cooler idles at 23 max is like 49. Added better cooling 5 120mm fans and installed new thermal paste.
ASRock K10N78M-PRO AM3/AM2+/AM2 NVIDIA GeForce 8200 Micro ATX AMD Motherboard
Kingston HyperX T1 Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
ARCTIC COOLING ACALP64 Pro 92mm CPU Cooler
AMD Phenom 9850 Black Edition 2.5GHz Socket AM2+ 125W Quad
Seagate Barracuda 7200.12 ST3250318AS 250GB 7200 RPM SATA
zotac gt520 video card- problem happened before i installed this
400 watt cooler master psu
used paste from oem first time just replaced yesterday with another brand same problem
Thanks. plus whats rig worth when i get it fixed?
scout_03
27,551
2,953
disable cool and quiet the air flow is from front to back,did you put oem paste or one from a maker,use this to see the temp and other reading report by the motherboard http://www.hwinfo.com/
popatim
30,980
7,155
You'll need a better cooler than that if you want to lower temps. That cooler is not much better than a stock cooler.
bigal80ak
119
4
shouldnt need better stock should be fine like i said i am running a much faster machine 6 core 3.2ghz and never above 48 thats with a more powerful card to and same case but i beleive the only option is a different cpu cooler. thanks
popatim
30,980
7,155
No, a stock cooler would not be fine with that overclock either, why would you think that?
Stock speed is 2.5ghz for that processor so get a cooler that can handle the heat or drop your OC is all I can recommend.
bigal80ak
119
4
it is not overclocked i did not say it was it has stock settings. an aftermarket cooler which you can read at top of the page. it is stock 2.5ghz.
bigal80ak
119
4
completely clean went over all of them and cleaned when i put new thermal paste on it the only thing i can think of is it does need new cpu cooler that one should be working a lot better though i dont understand it.
Similar threads
