Greetings. Today I swapped my PC's cpu fan which had also an attached backplate glued to the other side of the mobo. After an hour of wiggling I somehow managed to remove it without damaging the mobo. Or so I hope.I cleaned the cpu with isopropyl alcohol, I added a Hyper Tx3i with arctic silver 5, had the fan face outwards to the back with nothing obstructing it's airflow.
Unfortunately, the PC idles at 50-55c(122-131 Fahrenheit) according to speedfan.
One thing to note is that the new fan doesn't go over 1200rpm even at the aforementioned temperatures, and only cracks 1900rpm(max 2500) if the cpu workload hits 100%.
What could be the cause of this?
