TFT monitor displays Out of Range before WinXP loads
john
Splendid
Aug 25, 2003
3,819
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I'm not sure whether this is the right NG for this, but here goes!
I have WinXP Homeand a Geforce4 MX4000 video card with the most recent
drivers. The monitor is a 14inch TFT of "unknown" origin, but performs
well for my purposes.
On a couple of occasions, the following problem has occurred just
after turning the PC on:
The monitor is already powered up before the PC is started.
The startup screen (BIOS etc.) displays a normal (DOS like) display.
After the POST, and where I should see the Windows startup screen, the
display "whites out" and an Out of Range error is shown.
If I leave the PC on long enough for Windows to finish loading, I can
"hot plug" a CRT monitor which behaves perfectly, showing that the
refresh rate and resolution are within specification for the TFT
monitor.
If I plug the TFT monitor in again, all is well.
On odd one! But can anyone help?
(My suspicion falls on the monitor).
Regards
John Gruffydd (Mold, Wales, UK)
> goes!
> most recent
> performs
> just
> display.
> screen, the
> loading, I can
> the
> TFT
> monitor.
> Regards
Yes, it dose sound like the monitor, the BIOS should be out puting at
standared VGA so that any montor can support it, if the monitor canot
display it, then it’s a problem wiht the monitor. Asuming it works
with other monitors.
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Hardware-TFT-monitor-displays-Range-WinXP-loads-ftopict552802.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1753104
Most TFT monitors have only one native resolution and it can't be changed
without suffering consequences. It should be relatively easy for you to
check your manual to find out precisely what specs your monitor has. Then
meet these specs. Do not vary from them - at all!
Regards,
Richard Urban
If you knew as much as you thought you know,
You would realize that you don't know what you thought you knew!
<john@coedana.plus.com> wrote in message
news:e26gc1th62f03do86eedhvnf36escurqqi@4ax.com...
> monitor.
> Regards
On Sun, 3 Jul 2005 16:35:52 -0400, "Richard Urban"
Its native resolution is 1024 x 768 and that's what Windows is set to
deliver (and 70Hz refresh rate). As I said, this has only happened
twice and, when I plugged a CRT monitor in,
Desktop...Properties/Settings showed that these values had not
changed. In any case, the problem starts well before the Welcome
screen - it seems to happen when the Windows splash screen (with the
progress bar) should appear (just after POST has finished).
The monitor was given to me by my son - time to get another maybe!!
Regards
Set your refresh rate to 60hz and see what occurs! There is no need for
higher refresh rates as there is no 60hz flicker with TFT monitors, as there
is with CRT monitors!
Regards,
Richard Urban
news:vqmgc1lga1n6q5c0444rqh7odgf0oink97@4ax.com...
> Regards
> need for
> monitors, as there
> Regards,
> Richard Urban
> knew!
> can't be changed
> for you to
> monitor has. Then
> is set to
> happened
> not
> Welcome
> (with the
> maybe!!
> > Regards
LCD/TFT monitors dont actualy have a refresh rate.
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1753442
On Sun, 3 Jul 2005 17:55:14 -0400, "Richard Urban"
Thanks to all for their help. It happened again today, so I was able
to take a more considered action. This time, I simply removed the
monitor power plug for a few seconds and, when powered up again, it
behaved normally except that it was rather fuzzy. Hitting the "Auto"
button cured that.
I have now reset refresh rate to 60Hz so it will be interesting to see
if it makes a difference. My bet is that it's a monitor issue - a good
excuse to get a better one!
Regards
"Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message
news:uj0LP7AgFHA.3256@TK2MSFTNGP12.phx.gbl...
> Regards,
> Richard Urban
>> monitor.
>> Regards
news:uXJmlnBgFHA.352@TK2MSFTNGP09.phx.gbl...
> there is with CRT monitors!
> Regards,
> Richard Urban
>> Regards
