The Cause Of And Fix For Radeon R9 290X And 290 Inconsistency
Page 14 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Water cooling with a full or with Closed loop coolers does the trick. I have a H100 with two 120mm fans roof mounted on my Haf 912+ case to take care of CPU heat. Eventually I'm going to buy a 290x and probably a http://store.nzxt.com/NZXT-KRAKEN-G10-GPU-BRACKET-p/rl-krg10.htm with a outside mounted CPU cooler with inside fan to transfer GPU heat outside the case. PSU vents from bottom and exhausts back. The airflow inside of my HAF912+ is great and temps are pretty low with all case fans installed.
it is the manufacturer's duty to make sure all settings and the product work out of the box and not cause users' headaches.
