Leamon :
Another example of AMD basically lying to us. I swear they knew about crossfire issues, but did nothing to fix them until someone noticed. And now they're lying about the performance of their new card, someone noticed, and now they'll "fix" it. But they knew.
The CF issues aside, they cannot know how their partners boards will perform. Remember even though its the same PCB and everything, each partner has their own BIOS which will act a bit differently to the drivers.
Currently the 13.11 v9 beta drivers are not able to change my HD7970 Vapor-Xs fan speed but the 13.10s were.
megamanx00 :
Shame on you AMD. Shame. Too much promise, too big of a GPU die, and an inadequate cooler. It just seems that all the changes since letting go of Dirk Meyer have lead to a less competitive and less honest company.
That was a mistake. Dirk was the one who started all the things that are now making AMD able to continue.
But the past is the past.
Darkresurrection :
slomo4sho :
Hey Chris, thank you for the writeup. It brings up some interesting questions. Can you look into a few more details? Can you check and post the stock voltage along with the ASIC quality of each card? In addition, would you be willing to replace the thermal paste of each card and then rerunning the benchmarks in addition to providing pictures of the contact surface of each card?
Considering that there is still high variance between the two aftermarket cards after the fan calibration patch, with Asus being far inferior to Sapphire, there may be build quality concerns. For example, here are a couple images of 290X cooler, as you can see the build quality is lacking:
Sapphire is their main for making the reference PCBs and also tend to have better coolers than Asus. Not to say Asus makes bad cards but look at the R9-280X DCII vs the Toxic. The Toxic has the best thermals and also best clock speed.
jurassic512 :
AMD did this out of desperation to take the lead from nVIDIA, and in the hopes that you, the buyer, was as dumb as they hoped you'd be. Their own kick in the teeth comes in the form of the 290 making the 290X obsolete with it's $150 price difference with equal performance.
My last 5 cards have been AMD, but that doesn't make me blind to the truth.
This was a good read, Tom's. Thank you... we should all thank you.
you are a part of this show, 5 AMD cards!!!? really?!? you do not have even 1, desperately bla bla...get out of here dude... there was a slight problem with the fan RPM and now it is fixed, well tell you what, you are blind, you didn't even bother yourself to read the article, '' AMD was desperate
🙁, Nvidia is good performa, please buy Nvideo
🙁 please please...'' dude I own an r9-290 and
this 400$ monster nukes gtx 780, ...''Blinda ganepora nvideo please
AMD did an excellent job nuking Nvidia's *** , the problem was a slender one, which was defined in the software/ driver, it is solved, now everything is fine, if you didn't understand this after reading this article ok read this one http://www.extremetech.com/gaming/170636-well-that-was-quick-amd-solves-r9-290-throttling-problem-with-a-new-driver , if you still can't understand, don't blame others, you are dumb
Who are you to say he hasn't bought AMD cards for the past 5?
What if I said I did? I can even list them all for you:
All Sapphire
9700 Pro
9800XT
X850XTX PE
HD2900Pro 1GB
HD4870 1GB
HD5870 1GB
HD7970 Dual-X (Now in wifes machine)
HD7870 Dual-X (was in Wifes machine)
HD7970 Vapor-X (Current with plans to go to R9-290X when they have a decent cooler)
Would you like to fight me on what I am saying? Tell me I haven't bought those GPUs and that I am a liar?
slomo4sho :
jurassic512 :
What exactly is the truth? The 290 being faster than the GTX 780 at $100 less? The reference design fan speed issues are irrelevant for anyone waiting for a non-reference card and can easily be resolved by setting a custom fan profile? The amount of ignorance in this thread is astounding. It seems every mindless zombie flocks to this site and is incapable of obtaining information from multiple sources and drawing their own conclusions. Congratulations on joining that crowd
somebodyspecial :
I am a power user that seeks SILENT pc's. I buy specific stuff to get there or as near as I can to silent.
If noise is such a factor for you, why get worked up by a reference cooler? Non-reference designs and water cooling have always provided better acoustics and this applies to products from both the red and green team...
I agree that it doesn't matter except that they do need better reference coolers. It just looks bad.
Darkresurrection :
GOM3RPLY3R :
Darkresurrection :
Saga Lout :
Keep it civilised please, gentlemen. You can disagree with a comment but remember the first rule - attack the post, not the poster.
At the moment I have an itchy finger on my temporary ban hammer
we want to...really....just read his posts..
I think hes referring to you...
I don't think that babbling and incorrect grammar will get you anywhere.
Point being said, the 290x was fixed and where is stands now is it's price point. However, the 780ti was released a few weeks ago, and look at it. I checked the consistency and its right. For $200 more than a 290X, you can get a 780ti and have ~ 15-20% better performance than the 290X. The cards kinda equal out with the 290x winning in uber mode, but the temperature, sound, fan speed, and voltage in hand, Nvidia did a good job by having a back up plan.
Expect the 780ti with the aftermarket coolers to rise in price to ~$750-$800, then let the price drop like it usually does. You'll (estimate) be paying ~$600 for a card that is better than any other single gpu. Heck, the 780 Ti even beats the 690 and 670 Dual-Sli setups, its just insane. With the 680 Dual-Sli setups though, they come to about on par with the 780 ti just losing, but its just insane, There's no way the 290X can beat something like that unless every game from now on runs on that low quality OpenGL or comes with a full water cooling solution. ^_^
No he was not, because I had not started that war, and you'd better mind your own business mate, first of all since when 200$ difference is a slender one!? if that is the case I would buy radeon hd 7990, which smokes gtx 780ti, because
I noticed a price drop for hd 7990, now it is
available for 690$ with 8 free games any how it makes a little sense to buy gtx 780ti, in either price range, AMD has a far better offering... I know it is hard for nvidia to keep up...and they are losing market shares, but we can't help it can we!?
Actually he was. I have the same exact feelings as he does right now.
