All cables were connected according to GIGABYTE user manual, but PC does not beep or Power-On-Self-Test (POST).
The Heatsink CPU fan does not even spin. I am totally lost.
I can hear the SATA Hard disk drives (HDD) spinning but the IDE CD-ROM does not light up.
While the ATX 2x12 Main Power cable is connected, ATX-12V-2X4 is not found on my Power Supply (PSU).
The Gigabyte user manual is not easy to understand. Do two power connectors need to be used?
PWR_LED never turn on. F_Panel does not turn on. RJ-45 LAN Port LED lights are off.
There are no video signals sent to monitor.
All PHASE_LED lights on mainboard are on.
What can be done to debug this system build?
Is a 500W PSU with ATX-12V-2X4 needed?
Please help. Thank you.
System Specs
VGA: ATI PCI card
Monitor: Planar 15"
MB: GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboar
OS: Windows XP SP2
CPU: Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core
Sound: built-in
Memory: Kingston 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 850
PSU: Antec 430 Watts 80 PLUS Power Supply
HD: Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.
Cooling: Intel Stock HSF
System Specs
VGA: ATI PCI card
Monitor: Planar 15"
OS: Windows XP SP2
Sound: built-in
