Question Thermaltake RGB fan controller with b450m motherboard help please
Apr 26, 2020
So I have a thermaltake 200mm rgb fan and I want another 140 for the rear but thermaltake has their proprietary connectors and they are riing plus fans I'm just wondering if I get one of their controllers would it connect to my motherboard which is a b450m ds3h by gigabyte it only has one 4 pin header for the system fan and a 4 pin that says LED CPU right next to it if it would work connecting it all up how would I piece it together to be able to control all the fans connected to the motherboard thank you all so much!
Sadly you can't just buy a controller and put the propietary 6 pin fan. Those fans are suppouse to run at full speed. Is the way Thermaltake does to limit the second hand case fan market. But you can rewire the fans and control the speed by DC.
https://forums.tomshardware.com/thr...t-in-controller-no-fan-speed-control.3554260/
https://community.thermaltake.com/i...nnect-up-to-6-riing-rgb-fans-in-1-controller/
Dang that's really dumb I guess they have to make money somehow thank you for your help
