A few weeks ago I bought a 850W Thermaltake Toughpower GF1 on Amazon, which worked okay until a few days ago when it started to make a weird buzzing noise. I contacted Amazon and they sent me a replacement PSU (also a Toughpower GF1 850W) but to my surprise, when I took it out of the box it had a different connection layout, but it came with the same cables and manual. The replacement PSU only seems to have one EPS/CPU port instead of two and it comes with three PCI-E ports, unlike the first PSU I got which has 5 shared CPU/EPS + PCI-E ports, which is how they advertise it. Apparently even though they're both the same product name, the model numbers are different. The replacement PSU's model number is TTP-850AH3FSG-V and the defective one is TTP-850AH3FCG.
With the defective PSU, I used to plug in a 4 pin and an 8 pin EPS/CPU cable to the motherboard ports (for overclocking) as well as the 24 pin ATX connector, so my question is, can I plug in one of the 4+4 EPS/CPU cables in one of the 6+2 PCI-E ports in the replacement PSU, in order to power that motherboard connector? Or do I need to ask Amazon to send me a second replacement, this time with the correct layout? I'm attaching a photo of both PSUs, the top one is the replacement unit, the one in the bottom is the defective PSU.
Thanks!
Thanks!
